on 18-02-2022 09:12
Hi.
I'm seeing regular dropouts in the past couple of weeks. My broadband quality monitor shows big latency spikes of 160ms or more.
The network log on my router also has an error this morning, in addition to the regular T3 timeout errors:
RCS Partial Service;CM-MAC=...
Any assistance gratefully received.
on 02-03-2022 10:58
More dropped connections and poor latency yesterday and today. I've checked all cabling, but not done a factory reset yet, as it would be a pain in the middle of the day. I did, however, power cycle the hub ay 3pm yesterday (1st March).
01/01/1970 00:01:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/03/2022 14:59:40 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/03/2022 14:57:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2022 09:08:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2022 06:46:35 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/02/2022 20:41:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/02/2022 04:05:31 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 02-03-2022 11:03
Cable Modem Status
Item Status Comments
Acquired Downstream Channel (Hz) | 202750000 | Locked |
Ranged Upstream Channel (Hz) | 39400093 | Locked |
Provisioning State | Online |
on 02-03-2022 11:05
1 | 202750000 | -0.5 | 40 | 256 qam | 9 |
2 | 138750000 | -0.2 | 38 | 256 qam | 1 |
3 | 146750000 | 0 | 40 | 256 qam | 2 |
4 | 154750000 | -0.2 | 40 | 256 qam | 3 |
5 | 162750000 | -0.5 | 40 | 256 qam | 4 |
6 | 170750000 | -0.4 | 38 | 256 qam | 5 |
7 | 178750000 | -0.2 | 40 | 256 qam | 6 |
8 | 186750000 | -0.2 | 40 | 256 qam | 7 |
9 | 194750000 | -0.2 | 40 | 256 qam | 8 |
10 | 210750000 | -0.5 | 40 | 256 qam | 10 |
11 | 218750000 | -0.7 | 40 | 256 qam | 11 |
12 | 226750000 | -0.5 | 40 | 256 qam | 12 |
13 | 234750000 | -0.2 | 40 | 256 qam | 13 |
14 | 242750000 | -0.2 | 40 | 256 qam | 14 |
15 | 250750000 | 0 | 40 | 256 qam | 15 |
16 | 258750000 | 0 | 40 | 256 qam | 16 |
17 | 266750000 | 0 | 40 | 256 qam | 17 |
18 | 274750000 | 0 | 40 | 256 qam | 18 |
19 | 282750000 | 0 | 40 | 256 qam | 19 |
20 | 290750000 | 0 | 40 | 256 qam | 20 |
21 | 298750000 | 0.5 | 40 | 256 qam | 21 |
22 | 306750000 | 0.2 | 40 | 256 qam | 22 |
23 | 314750000 | 0.2 | 40 | 256 qam | 23 |
24 | 322750000 | 0 | 40 | 256 qam | 24 |
1 | Locked | 40.9 | 159 | 0 |
2 | Locked | 38.9 | 2787995 | 0 |
3 | Locked | 38.9 | 25359 | 0 |
4 | Locked | 38.9 | 183 | 0 |
5 | Locked | 40.3 | 182 | 985 |
6 | Locked | 38.9 | 184 | 0 |
7 | Locked | 40.3 | 177 | 0 |
8 | Locked | 40.3 | 177 | 0 |
9 | Locked | 40.9 | 179 | 0 |
10 | Locked | 40.3 | 139 | 0 |
11 | Locked | 40.3 | 122 | 0 |
12 | Locked | 40.9 | 98 | 0 |
13 | Locked | 40.3 | 87 | 0 |
14 | Locked | 40.9 | 88 | 0 |
15 | Locked | 40.9 | 95 | 0 |
16 | Locked | 40.3 | 162 | 0 |
17 | Locked | 40.9 | 126 | 0 |
18 | Locked | 40.3 | 104 | 0 |
19 | Locked | 40.9 | 153 | 0 |
20 | Locked | 40.3 | 98 | 0 |
21 | Locked | 40.3 | 100 | 0 |
22 | Locked | 40.3 | 79 | 0 |
23 | Locked | 40.3 | 88 | 0 |
24 | Locked | 40.3 | 90 | 0 |
on 02-03-2022 11:05
1 | 39400093 | 45.8 | 5120 | 64 qam | 4 |
2 | 60300000 | 46.8 | 5120 | 64 qam | 1 |
3 | 53700000 | 46.3 | 5120 | 64 qam | 2 |
4 | 46200000 | 46 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 02-03-2022 11:06
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt060-b.cm |
SFID | 57588 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 57587 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 02-03-2022 11:09
on 02-03-2022 12:22
Hi gninja,
Thanks for posting and welcome back to the community!
Sorry for any issues faced.
From checking our service again I can't really see any readings that would attribute to the issue.
However I've dropped you a PM so our team can investigate this further.
You'll see this through the purple envelope icon at the top right hand side.
on 22-03-2022 11:08
A Virgin engineer visited yesterday. He replaced a couple of old splitters and attenuators and changed to a different port at the cabinet.
This boosted the power levels on the downstream channels to 2.0 dBmV or higher, but made no practical difference to dropouts due to latency / dropped packets.
The engineer pointed out that I had one of the old style brown coax / phone cables between the house and the cabinet, but that he tested it and it seemed good. I asked for that to be replaced, and that's been booked in 2 weeks from tomorrow.
I suspect the real issue here is nothing to do with my equipment or connections, but congestion further upstream, while the whole neighbourhood joins Zoom meetings, but I have no data on Virgin's cabinets. If that were the case, my only option would be to look for other suppliers.
on 24-03-2022 12:10
Hi @gninja,
Thank you for your update on the situation. You can manage your appointments on your online account if needed.
Please keep us updated on how the cable replacement goes and if you need any further assistance from us during this time. We'll be happy to help.
Thank you.
on 07-04-2022 17:05
Cable from the house to the cabinet was replaced today. No difference in latency.
