Russkev
  • 5
Message 1 of 10
Dropouts and slow spped
Over the last few weeks I have experienced a major drop out and since then poor speed. I used to get >=100 MBps bit now struggle to get 40 mbps. I have restarted my router recently and is still only showing 30 Mbps
i am in the Stevenage area so wondered if anyone else experiencing similar issues please?
thanks
kevin
  • 16.28K
  • 711
  • 1.6K
Message 2 of 10
Re: Dropouts and slow spped
This by wireless?
Russkev
  • 5
Message 3 of 10
Yes I’ve not tested directly with Ethernet cable. I will try do today
ChaCha47
Message 4 of 10
I’m having similar issues since being sent the new Hub. When I installed it I got speed of over 200mbps. One week later I struggle to get over 20-40mb and connection keeps dropping out.
 Thank you Virgin for removing the feature to run a test against the new hub as I now have no way to flag poor service without calling and spending an eternity on hold.
Tags (1)
Russkev
  • 5
Message 5 of 10
Mine has been fine when I had the new router a few months back getting ~100 Mbps bit since a major outage a week or so ago, it down to 30-40Mbps. Will test later with Ethernet cable. If it’s bad will sit on queue to Virgin.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 10
@ChaCha47 wrote:
... snip ...
If you want assistance please start your own thread.
Russkev
  • 5
Message 7 of 10
I tested last night using an Ethernet cable to my laptop and ran a speed test and it showed 100Mbps. I also did a Wi-fi speed test using laptop and came back with 60-70’Mbps. I then did a speed test on my iPhone and again it shows 30-40Nbps. Seems issue is with my iPhone connection and that was stood by the router. I did try bad enable the 5G connection as the Virgin app seems to stare 2.4G only.
any thoughts anyone please?
  • 16.28K
  • 711
  • 1.6K
Message 8 of 10
What laptop model do you have as it might only have a 100Mb NIC by wire.
Russkev
  • 5
Message 9 of 10
It’s a B&O ELITEBOOK but gave me the correct speed both on Ethernet and also wi-Fi. Something has to have changed on my iPhone
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 10
On the laptop label there will be a model number eg BO8910AB.
What is it on yours ?
