  • 39
Pollyp40
Message 1 of 5
Drop in speed using IPVanish
Hard wired download speed, via Superhub 3, drops from >100Mbs to <10 Mbps when using IPVanish VPN.
Is this normal?
Is a VPN really needed?
  • 11.74K
  • 778
  • 3.45K
Message 2 of 5
Re: Drop in speed using IPVanish
Needed for what?
If you are accessing geolocked content, you may need a VPN with a gateway in the region its locked to. They can help with routing if you are gaming.
Other than that- your wasting your money.
Click to learn more about VIP
Use Kudos to say thanks
  • 2.78K
  • 139
  • 405
jpeg1
Trouble shooter
Message 3 of 5
Your speed will inevitably be lower using a VPN.  Some are worse than others.
It's not needed for an ordinary user...
  • 933
  • 43
  • 120
happywithmy350
Well-informed
Message 4 of 5
I use Astrill as it actually runs my service full speed and I am a dodgy geezer <shady look>
  • 11.74K
  • 778
  • 3.45K
Message 5 of 5
If your a dodgy geezer, a VPN wont protect you....The expression "snake-oil" springs to mind...
