  • 15.27K
  • 1.16K
  • 1.91K
Message 11 of 14
Re: Download speed 1.8 MB, upload speed 0MB on 100MB package
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
  • 9
Message 12 of 14
This is through wifi. I do  not have any devices cable right now to check speed.
Settling in
Message 13 of 14
Exact same here however yesterday, for an hour I had 40mbps downloading speed and 3mbps uploading, then it gone...
  • 5.7K
  • 648
  • 1.9K
Message 14 of 14
@eli2 While you may have identical symptoms, you are better starting your own thread as this doesn't sound to me like a generic issue and is specific to an individual connection.
Having multiple users discussing different issues (however similar the symptoms) tends to confuse things for those of us try to assist, including the VM staff.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
