on 13-01-2023 16:25
So I noticed some repeated issues connecting to my PLEX server from outside the home (WAN) and then speed tests showed a notable slowdown of my upload speed (38Mbps>~20Mbps). I rebooted everything but after checking my BBQM I tracked an issue back to the 11th Jan. See below a clear issue beginning around 10am where dropped packets appeared and stayed. I checked with Virgin support page and their site did say there was as "intermittent signal issue in your area".
Download seems fine if a little slower (387Mbps>370Mbps) but streaming is fine etc.
Do I sit tight and wait for it to be resolved or report this to VM?
Answered! Go to Answer
on 13-01-2023 17:07
If there is an ongoing issue, VM will not send a technician to you to resolve any issues.
You should call in and get a Fault Reference so you can keep asking until it is fixed ..... Note fix dates are given are usually estimates, not firm dates.
on 13-01-2023 16:29
on 13-01-2023 16:43
The web page says no problems but the phone line said "we're sorry that you are still having intermittent problems in your area...our engineers are working hard to fix this but its a really complex issue...."
on 13-01-2023 17:07
on 14-01-2023 14:57
All fixed! I got a text telling me it was fixed too so I expect that was because I called the automated number you gave me from my mobile phone (registered to my VM account). Upload is back to max speed and my PLEX server is running perfectly over my WAN now. Thanks!
