on 02-11-2022 19:11
I game most evenings and I noticed in the last week that I was losing packets and my in-game ping would go nuts.
First noticed 10 days ago when I was streaming and my OBS was having real issues dropping 25% of the frames and struggling to get more than 1.5Mb upload (I should have 50Mb up)
I reset my switch, reseated all my ethernet cables and rebooted my hub.
Back to normal 🙂
Next evening, the same happened.
Every day since it's been the same. Fine until the evening when I'm about to game and I do a ping test to cloudflare to make sure everything's stable. I see ping spikes and when I do a speed test it creeps up to my download and the upload starts about 12mb and drops from there.
Tried the VM "helper", but it just says to reset everything and when I say it doesn't help it says to try again tomorrow (it does work, but only for 24hrs).
Last thing I tried was a factory reset of the hub yesterday and re-seated the VM cable.
Today, same latency/ping issues, so I'm 100% sure the hub that needs replaced as a reboot of that fixes it every time. Albeit temporary
Speedtests while it's having issues:
https://www.speedtest.net/result/13851401847
https://www.speedtest.net/result/13851407322
Example ping:
Reply from 1.1.1.1: bytes=32 time=105ms TTL=57
Reply from 1.1.1.1: bytes=32 time=107ms TTL=57
Reply from 1.1.1.1: bytes=32 time=86ms TTL=57
Reply from 1.1.1.1: bytes=32 time=83ms TTL=57
Reply from 1.1.1.1: bytes=32 time=74ms TTL=57
Reply from 1.1.1.1: bytes=32 time=91ms TTL=57
Reply from 1.1.1.1: bytes=32 time=10ms TTL=57
Reply from 1.1.1.1: bytes=32 time=7ms TTL=57
Reply from 1.1.1.1: bytes=32 time=28ms TTL=57
Reply from 1.1.1.1: bytes=32 time=48ms TTL=57
Reply from 1.1.1.1: bytes=32 time=17ms TTL=57
Reply from 1.1.1.1: bytes=32 time=37ms TTL=57
Reply from 1.1.1.1: bytes=32 time=9ms TTL=57
Reply from 1.1.1.1: bytes=32 time=8ms TTL=57
Reply from 1.1.1.1: bytes=32 time=15ms TTL=57
Reply from 1.1.1.1: bytes=32 time=16ms TTL=57
Reply from 1.1.1.1: bytes=32 time=39ms TTL=57
Reply from 1.1.1.1: bytes=32 time=30ms TTL=57
Reply from 1.1.1.1: bytes=32 time=12ms TTL=57
Speedtest after reboot:
https://www.speedtest.net/result/13851441588
Example ping after a hub reboot:
Reply from 1.1.1.1: bytes=32 time=13ms TTL=57
Reply from 1.1.1.1: bytes=32 time=11ms TTL=57
on 02-11-2022 19:17
on 02-11-2022 19:30
on 02-11-2022 19:45
on 02-11-2022 21:41
Thanks for the reply.
If it was a connectivity issue then I wouldn't expect a reboot of the hub to fix it every time.
WiFi isn't an problem as I hard-wire everything
on 02-11-2022 22:11
on 03-11-2022 14:42
@c11umw wrote:Thanks for the reply.
Lose connectivity and reboot goes through the remake connection procedure and can connect - no?
Lets look at the Hub stats and connection data. can you do this....
First post up the link to "share live BQM" so we can see how good/bad the larency actually is.
Then, In your browser’s URL box type in... http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return.
If you have a Hub4 or 5 then login on the first page up. If you have an SH2 or Hub3 - dont log in - just click on the “router status” icon/text at bottom-middle (Hub3) or top/right (SH’s) of the Login page.
Then Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 04-11-2022 22:39
Yea, I did think after that that it could be struggling to cope with poor latency and if not coded right get itself into a downward spiral.
Although it's been perfectly happy for the last 18 month or so (until 2 weeks ago) so I discounted it as unlikely.
Here's the live chart as requested
As you can see - chaos ensued
Here's a corresponding Ookla Speedtest (it download crept up from 20mb to 930):
https://www.speedtest.net/result/13897463726
on 04-11-2022 22:41
Hub pages
25 | 331000000 | 22.199997 | 40.366287 | QAM256 | 25 |
6 | 179000000 | 23.800003 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 23.800003 | 40.366287 | QAM256 | 7 |
8 | 195000000 | 23.599998 | 40.366287 | QAM256 | 8 |
9 | 203000000 | 23.500000 | 40.366287 | QAM256 | 9 |
10 | 211000000 | 23.400002 | 40.946209 | QAM256 | 10 |
11 | 219000000 | 23.599998 | 40.946209 | QAM256 | 11 |
12 | 227000000 | 23.500000 | 40.946209 | QAM256 | 12 |
13 | 235000000 | 23.599998 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 23.800003 | 40.946209 | QAM256 | 14 |
15 | 251000000 | 23.900002 | 40.946209 | QAM256 | 15 |
16 | 259000000 | 24.199997 | 40.946209 | QAM256 | 16 |
17 | 267000000 | 23.900002 | 40.946209 | QAM256 | 17 |
18 | 275000000 | 23.400002 | 40.366287 | QAM256 | 18 |
19 | 283000000 | 22.800003 | 40.946209 | QAM256 | 19 |
20 | 291000000 | 22.800003 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 23.000000 | 40.946209 | QAM256 | 21 |
22 | 307000000 | 22.900002 | 40.366287 | QAM256 | 22 |
23 | 315000000 | 22.800003 | 40.366287 | QAM256 | 23 |
24 | 323000000 | 22.599998 | 40.366287 | QAM256 | 24 |
26 | 339000000 | 22.400002 | 40.366287 | QAM256 | 26 |
27 | 347000000 | 22.699997 | 40.366287 | QAM256 | 27 |
28 | 355000000 | 22.800003 | 40.946209 | QAM256 | 28 |
29 | 363000000 | 22.699997 | 40.366287 | QAM256 | 29 |
30 | 371000000 | 22.699997 | 40.366287 | QAM256 | 30 |
31 | 379000000 | 23.000000 | 40.946209 | QAM256 | 31 |
32 | 387000000 | 22.800003 | 40.366287 | QAM256 | 32 |
33 | 491000000 | 21.400002 | 40.366287 | QAM256 | 33 |
34 | 499000000 | 21.400002 | 40.366287 | QAM256 | 34 |
35 | 507000000 | 20.599998 | 40.366287 | QAM256 | 35 |
36 | 515000000 | 20.400002 | 40.366287 | QAM256 | 36 |
25 | Locked | 40.366287 | 7 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 40.366287 | 1 | 0 |
10 | Locked | 40.946209 | 2 | 0 |
11 | Locked | 40.946209 | 2 | 0 |
12 | Locked | 40.946209 | 2 | 0 |
13 | Locked | 40.366287 | 1 | 0 |
14 | Locked | 40.946209 | 0 | 0 |
15 | Locked | 40.946209 | 1 | 0 |
16 | Locked | 40.946209 | 2 | 0 |
17 | Locked | 40.946209 | 5 | 0 |
18 | Locked | 40.366287 | 1 | 0 |
19 | Locked | 40.946209 | 2 | 0 |
20 | Locked | 40.366287 | 5 | 0 |
21 | Locked | 40.946209 | 4 | 0 |
22 | Locked | 40.366287 | 6 | 0 |
23 | Locked | 40.366287 | 3 | 0 |
24 | Locked | 40.366287 | 7 | 0 |
26 | Locked | 40.366287 | 11 | 0 |
27 | Locked | 40.366287 | 7 | 0 |
28 | Locked | 40.946209 | 7 | 0 |
29 | Locked | 40.366287 | 7 | 0 |
30 | Locked | 40.366287 | 9 | 0 |
31 | Locked | 40.946209 | 13 | 0 |
32 | Locked | 40.366287 | 12 | 0 |
33 | Locked | 40.366287 | 9 | 0 |
34 | Locked | 40.366287 | 16 | 0 |
35 | Locked | 40.366287 | 20 | 0 |
36 | Locked | 40.366287 | 16 | 0 |
04-11-2022 22:41 - edited 04-11-2022 22:42
37 | 96 | 4K | 1880 | QAM4096 | 392 |
37 | Locked | 43 | 21.6 | 545631624 | 0 |
1 | 43100000 | 38.020599 | 5120 KSym/sec | 32QAM | 2 |
2 | 30100000 | 37.770599 | 5120 KSym/sec | 32QAM | 4 |
3 | 36600000 | 38.020599 | 5120 KSym/sec | 32QAM | 3 |
4 | 23600000 | 37.270599 | 5120 KSym/sec | 16QAM | 5 |
5 | 49600000 | 38.520599 | 5120 KSym/sec | 64QAM | 1 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 7 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
6 | 10.8 | 34.0 | 2K | QAM8 |
6 | OFDMA | 220 | 53.4 | 7 | 0 |
Thu Jan 1 00:01:26 1970 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:27 1970 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:38 1970 | 4 | Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 1 11:45:40 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 1 11:52:01 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 1 12:23:06 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 2 11:54:39 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:24 1970 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:24 1970 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 2 19:34:55 2022 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 2 19:57:47 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Nov 4 13:00:13 2022 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Nov 4 13:14:55 2022 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
