on 13-02-2022 12:16
I have recently had a problem.
I upgraded my M500 to 1GB and am not getting any think like the speeds that I should and am just getting over 535mb
Strangely my upload speeds are 50 to 52mb so in the right provisioning band for 1GB product and they if I am correct in my thinking on DOCSIS 3.0 (and the D/L on 3.1)
I have had two engineer visits and still no further on, equipment and FTTP are okay
I am using a HUB4 which has been changed, but no change in speeds.
The provisioning appears to be correct and the levels are ok
My question is this, has anyone got a HUB4 with a wideband -3db attenuator that is getting 1GB+
On rebooting my Hub4 the QAM starts at 4096 and within 20 minutes drops to 2048, my speeds never seem to go above 550mb(measured direct at the HUB with 1GB nic and cat6 cable. (this happens with or without the attenuator in place)
I have ruled out everything else and am coming to the conclusion that it might be something with the attenuator or a miss match from the cabinet.
Unfortunately there is no one else on my cabinet on 1GB so can't even find out if it is a local issue which is starting to get frustrating
Any help or idea appreciated
on 05-03-2022 10:43
159 | 96 | 4K | 1880 | QAM2048 | 424 |
error occurring after 12 mins
DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=ac:f8:xx:xx:xx:xx;CMTS-MAC=00:eb:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
on 05-03-2022 10:45
on 05-03-2022 10:51
All the levels and stats look fine, the line has been tested, the router changed the only thing I can think of is that there is an incorrect provision somewhere on the network as the router has been changed and is showing the correct provision
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
25 | 331000000 | 1.2 | 39 | QAM256 | 25 |
1 | 139000000 | 2.7 | 39 | QAM256 | 1 |
2 | 147000000 | 2.6 | 39 | QAM256 | 2 |
3 | 155000000 | 2.7 | 39 | QAM256 | 3 |
4 | 163000000 | 2.7 | 39 | QAM256 | 4 |
5 | 171000000 | 2.8 | 39 | QAM256 | 5 |
6 | 179000000 | 2.9 | 39 | QAM256 | 6 |
7 | 187000000 | 2.9 | 39 | QAM256 | 7 |
8 | 195000000 | 3 | 39 | QAM256 | 8 |
9 | 203000000 | 3 | 39 | QAM256 | 9 |
10 | 211000000 | 2.9 | 40.4 | QAM256 | 10 |
11 | 219000000 | 2.9 | 40.9 | QAM256 | 11 |
12 | 227000000 | 2.9 | 40.4 | QAM256 | 12 |
13 | 235000000 | 2.8 | 39 | QAM256 | 13 |
14 | 243000000 | 2.9 | 40.9 | QAM256 | 14 |
15 | 251000000 | 2.7 | 39 | QAM256 | 15 |
16 | 259000000 | 2.7 | 40.4 | QAM256 | 16 |
17 | 267000000 | 2.2 | 40.4 | QAM256 | 17 |
18 | 275000000 | 2 | 40.4 | QAM256 | 18 |
19 | 283000000 | 2 | 40.4 | QAM256 | 19 |
20 | 291000000 | 2.3 | 40.4 | QAM256 | 20 |
21 | 299000000 | 2.6 | 40.4 | QAM256 | 21 |
22 | 307000000 | 2.1 | 40.4 | QAM256 | 22 |
23 | 315000000 | 1.8 | 40.4 | QAM256 | 23 |
24 | 323000000 | 1.3 | 39 | QAM256 | 24 |
26 | 339000000 | 1.5 | 40.4 | QAM256 | 26 |
27 | 347000000 | 1.6 | 39 | QAM256 | 27 |
28 | 355000000 | 1.3 | 40.4 | QAM256 | 28 |
29 | 363000000 | 1.3 | 39 | QAM256 | 29 |
30 | 371000000 | 1.5 | 40.4 | QAM256 | 30 |
31 | 379000000 | 1.4 | 39 | QAM256 | 31 |
on 05-03-2022 10:52
25 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
4 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.946209 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 40.946209 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
159 | Locked | 43 | 2.5 | 498358109 | 0 |
on 05-03-2022 10:53
1 | 60300000 | 36 | 5120 KSym/sec | 64QAM | 1 |
2 | 39400000 | 35.3 | 5120 KSym/sec | 64QAM | 4 |
3 | 46200000 | 35.3 | 5120 KSym/sec | 64QAM | 3 |
4 | 53700000 | 36 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
on 05-03-2022 10:53
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | 87dsfd;kfoA,.iyewrkldJKDHSUBs |
SFID | 28819 |
Max Traffic Rate | 1200000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 29465 |
Max Traffic Rate | 55000270 |
Max Concatenated Burst | 16320 |
Scheduling Type | bestEffort |
on 05-03-2022 11:04
error log (same event every reboot)
Fri 04/03/2022 17:32:41 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=ac:f8:xx:xx:xx:xx;CMTS-MAC=00:eb:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
Fri 04/03/2022 17:44:57 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=ac:f8:xx:xx:xx:xx;CMTS-MAC=00:eb:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1; |
MAC ac:f8:xx:xx:xx:xx ARRIS Router (HUB4)
MAC 00:eb:**:**:**:** CISCO (Cabinet)
on 07-03-2022 11:23
Hello @ST4,
Welcome back, thanks for posting.
I am sorry for any issues with your broadband.
I have checked our system, I am not able to see any known issues causing any problems.
How is your service for you today?
Many thanks,
on 08-03-2022 18:08
No further on, I have applied to cancel my line
on 10-03-2022 18:20
Hi @ST4, thanks for your reply and I'm very sorry to hear that.
We have exhausted all of our checks at the moment and there is no reason you should still be getting just 500mbps or under. I'll leave this thread open in case you need our support until you disconnect, or we can provide any further support.
Sincere apologies.
Many thanks
