Gizza
Message 1 of 8
Crap speed
only getting 8 should be 100 any ideas
  • 12.96K
  • 989
  • 2.98K
Message 2 of 8
Re: Crap speed
wired or wireless - always test wired
____________________
Tony
  • 12
dan78uk
Message 3 of 8
Re: Crap speed
Translated to me this means: "surely it's the broadband but I'm saying its something else"
  • 12.96K
  • 989
  • 2.98K
Message 4 of 8
Re: Crap speed
if you test wired and get full speed then there is no fault with the input - if then you get slow speeds via wifi you need to look at the reasons - VM sell speed to the modem and thats wired
if the speed is slow wired then thats a different matter and needs investigation from VM
Tony
  • 8.58K
  • 880
  • 1.33K
Message 5 of 8
Re: Crap speed
If you think that you have a BB speed problem, then to check the speeds coming in to your Hub properly, and they match what you should be getting, you need to do this first.
Make sure your device has a gigabit network card with up to date drivers. Use a new Cat6a ethernet cable to connect it to the Hub - which you have put into modem mode (to ensure only your device is connected). Then boot up your device into "safe mode" (to disable any software on it that could be limiting speeds) and run the test at speedtest.net on 2 different browsers one of which is a fresh download (e.g. Opera?).
Is that how you did yours ?
  • 12
dan78uk
Message 6 of 8
Re: Crap speed
So are you saying that I need a gigabit network card to test 5mb/s download speed????
I know already if I'm doing this in 2 hours I will get full speed go explain me that
  • 5
Chris34731
Message 7 of 8
Re: Crap speed
It annoys me when you are asked to test wired considering the last few years most devices support 5g wifi and give you the same speed as you get on an Ethernet cable I get 109mb on my mobile same as I get on the laptop wired last few days internet has been utter crap and i've beeen getting 15mb
All these issues have arised since greedy virgin bleedia have expanded it's network into non virgin areas but don't invest in it's network to handle such speeds and data and I know this because I was a virgin engineer for 6 years and when I had staff broadband the problems started when virgin installed the estate down the road. I was promised 40mb with sky fibre and that's what I got 99 percent of the time think I'll be going back to it soon may be not as fast in terms download speed but least it was reliable and worked
  • 12.96K
  • 989
  • 2.98K
Message 8 of 8
Re: Crap speed
it may annoy you and in some cases what you say is correct but many still use older phones and tablets to test wifi - they are limited to about 40 down but users complain that they are not getting the full speed down on wifi when they are on speeds like 350
VM do not sell wifi - or thats what they say - they sell speed to the modem - to know if thats ok then the equipment used for testing has to be capable of using and showing that speed
you obviously know all that and have mobile devices capable of working at high speeds - many do not
so the gigabit lan - cat5e/cat6 and modem mode test is useful - it also helps to prove if the fault lies with VM or the user
not everyone is a tech savvy as you so its best to start with the lowest common denominator
Tony
