  • 4.6K
  • 309
  • 768
Roger_Gooner
Superstar
Message 11 of 12
Re: Continued low speed.
The Ethernet cable to the hub in modem mode must be the only cable as having done so the other three LAN ports will not be active.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 16
orthodoxuk
Message 12 of 12
Hi, following previous suggestion: can anyone tell me where to find in the Hub 3 settings, information that will show that my hub is set for 350Mbps?
Thanks.
