on 11-10-2022 12:55
For the last month or so I've been getting constant low levels of packet loss (note the red signal at the top of the chart):
It doesn't seem to be affecting general day to day usage, but clearly something's not quite right. Rebooting the hub doesn't make any difference. The VM service page isn't working right now but last time I checked it indicated problems with TV in my area, but no issues with broadband.
Any ideas?
1 | 258750000 | -3.5 | 37 | 256 qam | 16 |
2 | 138750000 | 0.2 | 37 | 256 qam | 1 |
3 | 146750000 | 0 | 37 | 256 qam | 2 |
4 | 154750000 | -0.7 | 37 | 256 qam | 3 |
5 | 162750000 | -1 | 37 | 256 qam | 4 |
6 | 170750000 | -1.5 | 37 | 256 qam | 5 |
7 | 178750000 | -1.9 | 37 | 256 qam | 6 |
8 | 186750000 | -2.2 | 37 | 256 qam | 7 |
9 | 194750000 | -2.7 | 37 | 256 qam | 8 |
10 | 202750000 | -3 | 37 | 256 qam | 9 |
11 | 210750000 | -3.5 | 37 | 256 qam | 10 |
12 | 218750000 | -3.9 | 37 | 256 qam | 11 |
13 | 226750000 | -4.5 | 37 | 256 qam | 12 |
14 | 234750000 | -4.7 | 37 | 256 qam | 13 |
15 | 242750000 | -4.7 | 37 | 256 qam | 14 |
16 | 250750000 | -4.2 | 37 | 256 qam | 15 |
17 | 266750000 | -3.9 | 37 | 256 qam | 17 |
18 | 274750000 | -3.7 | 37 | 256 qam | 18 |
19 | 282750000 | -3.5 | 37 | 256 qam | 19 |
20 | 290750000 | -4 | 37 | 256 qam | 20 |
21 | 298750000 | -3.7 | 37 | 256 qam | 21 |
22 | 306750000 | -3.7 | 37 | 256 qam | 22 |
23 | 314750000 | -4.2 | 37 | 256 qam | 23 |
24 | 322750000 | -4.2 | 37 | 256 qam | 24 |
1 | Locked | 37.6 | 474 | 0 |
2 | Locked | 37.3 | 144 | 0 |
3 | Locked | 37.6 | 166 | 0 |
4 | Locked | 37.6 | 244 | 0 |
5 | Locked | 37.6 | 347 | 0 |
6 | Locked | 37.6 | 253 | 0 |
7 | Locked | 37.3 | 214 | 0 |
8 | Locked | 37.3 | 223 | 0 |
9 | Locked | 37.6 | 272 | 0 |
10 | Locked | 37.3 | 357 | 0 |
11 | Locked | 37.3 | 578 | 0 |
12 | Locked | 37.6 | 647 | 0 |
13 | Locked | 37.6 | 1001 | 0 |
14 | Locked | 37.3 | 1295 | 0 |
15 | Locked | 37.3 | 1128 | 0 |
16 | Locked | 37.6 | 735 | 0 |
17 | Locked | 37.6 | 756 | 0 |
18 | Locked | 37.6 | 586 | 0 |
19 | Locked | 37.3 | 645 | 0 |
20 | Locked | 37.6 | 875 | 0 |
21 | Locked | 37.3 | 681 | 0 |
22 | Locked | 37.6 | 766 | 0 |
23 | Locked | 37.6 | 1063 | 0 |
24 | Locked | 37.6 | 998 | 0 |
1 | 43100000 | 44.5 | 5120 | 64 qam | 2 |
2 | 49599976 | 44.8 | 5120 | 64 qam | 1 |
3 | 30100000 | 44.8 | 5120 | 64 qam | 4 |
4 | 36600000 | 44 | 5120 | 64 qam | 3 |
5 | 23600110 | 47.2 | 5120 | 16 qam | 5 |
1 | ATDMA | 0 | 0 | 3 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 12 | 0 |
on 04-11-2022 12:12
The status service page says that there are no problems in my area, but when I ran the test on my hub it came back with this result:
There’s a broadband issue in your area and our technicians are on the case to fix things. Check back here at any time for updates.
on 04-11-2022 12:29
When that local work is finished, check your stats again. One of the upstream channels is not connected correctly, which could explain your slow uploads. And the downstream levels are now rather too high.
on 04-11-2022 13:36
Interesting. I rebooted the hub at about midday and now the packet loss problem seems to have disappeared, although it may still be too early to tell for sure:
However, my upload speed is still only ~5Mbps. Upstream channels currently look like this:
1 | 43100000 | 33.3 | 5120 | 32 qam | 2 |
2 | 49600107 | 33.5 | 5120 | 64 qam | 1 |
3 | 36600000 | 33 | 5120 | 64 qam | 3 |
4 | 23600118 | 36.5 | 5120 | 16 qam | 5 |
5 | 30100000 | 34 | 5120 | 32 qam | 4 |
I'll try rebooting the hub again...
on 04-11-2022 13:55
Upstream channels look the same after the reboot:
2 | 49600000 | 33.5 | 5120 | 64 qam | 1 |
3 | 36600000 | 33.3 | 5120 | 64 qam | 3 |
4 | 23600000 | 36.5 | 5120 | 16 qam | 5 |
Upload speed is still capped at 4-5Mbps. I'll wait a bit and try again.
on 04-11-2022 14:26
Your upstream connection is very poor now. It needs a technician to sort it out.
on 04-11-2022 14:34
Alex from VM confirmed that there is some kind of outage in my area. Hopefully once that's fixed everything will be golden 🤞
For what it's worth, packet loss seems to have returned after the latest reboot, but none of these results are worth much while this infrastructure outage is ongoing.
on 07-11-2022 08:50
Thank you for updating the thread tievolu.
Just to provide further information, the issue is related to SNR (Signal to Noise Ratio) and the current estimated fix date is the 11th November 9am.
on 11-11-2022 15:49
Looking better today. Upload speeds are back to normal and the background packet loss is still there but appears to be tailing off.
on 12-11-2022 17:51
Hope you get this sorted soon. Just to set expectation i had a similar issue about mid 2021, the packet loss was on the upsteam, it was a known issue in the area that was fixed 3 times i think, overall it took about 6 months for the problem to be properly fixed. I now have the same issue again 11 months on with constant packet loss on the upstream. last time it occurred following works in my area and the same this time.
on 12-11-2022 18:02
Do you have your own router or you run only the Superhub?
If is the only the Superhub in router mode than get your own router and set SH in Modem Mode. At least you eliminate a fat chunk of the issue and hopefully they will fix the signal issues at some point but don't hold your breath
The super hubs generally can't do more than 100 mbit service without packet loss. Superhubs Puma chipsets issues never been fully resolved by the firmware updates.
VM never fixed my issues with Packet Loss to my old address for 4 years I used to have SH 3 back than.
