Jamiemilne
  • 30
Message 1 of 30
Consistent Low Download Speed
Hi, we signed up to M350 Fibre Broadband last June. It is very rare that when I do a speedtest that I get anything above 100.
The most common results that I get are between 40mpbs and 70mpbs.
What could be causing this? Its frustrating to be paying a bill for high speed broadband and never getting anywhere close to what the package is.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 30
Re: Consistent Low Download Speed
How are you connecting Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Jamiemilne
  • 30
Message 3 of 30
Thanks.
One pc is connected by Ethernet cable, and the rest of the devices are wifi. Should I set up the broadband monitor using the pc connected directly to the router?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 30
Whichever is easiest for you, the device that you set up the BQM with is immaterial the BQM stops at the Hub or Router if you have one behind the Hub..
Jamiemilne
  • 30
Message 5 of 30
Jamiemilne
  • 30
Message 6 of 30
13150000006.338256 qam23
22030000006.138256 qam9
3211000000638256 qam10
42190000005.940256 qam11
52270000005.838256 qam12
62350000005.838256 qam13
72430000005.638256 qam14
82510000005.640256 qam15
92590000005.938256 qam16
10267000000638256 qam17
112750000006.140256 qam18
12283000000640256 qam19
132910000006.138256 qam20
142990000006.338256 qam21
15307000000638256 qam22
163230000006.138256 qam24
17331000000638256 qam25
183710000005.538256 qam26
193790000005.538256 qam27
203870000005.440256 qam28
213950000005.338256 qam29
224030000005.338256 qam30
234110000005.338256 qam31
244190000005.338256 qam32
1Locked38.9519974
2Locked38.9572746
3Locked38.6404857
4Locked40.3241908
5Locked38.94331011
6Locked38.93381072
7Locked38.9498943
8Locked40.31021976
9Locked38.95671012
10Locked38.9359842
11Locked40.3365840
12Locked40.3626889
13Locked38.9473886
14Locked38.9513937
15Locked38.9562794
16Locked38.915341018
17Locked38.6951888
18Locked38.9358911
19Locked38.6695939
20Locked40.3818917
21Locked38.9616865
22Locked38.9744981
23Locked38.9411859
24Locked38.94671047
Jamiemilne
  • 30
Message 7 of 30
1536999604.8512064 qam2
2393999804.675512064 qam4
3462000884.725512064 qam3
4603000984.875512064 qam1
3ATDMA0000
4ATDMA0000
Jamiemilne
  • 30
Message 8 of 30
13/08/2020 11:58:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 10:11:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 23:12:6ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 19:46:48ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 17:25:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/08/2020 19:50:9ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 17:08:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 15:29:58ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2020 16:46:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 21:20:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 05:26:36ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 01:56:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 00:31:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 01:24:54ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 18:28:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/07/2020 18:38:55ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/07/2020 07:39:47ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/07/2020 03:15:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/07/2020 20:40:43ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 11:15:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Jamiemilne
  • 30
Message 9 of 30
Jamiemilne
  • 30
Message 10 of 30
is anyone from Virgin on here that could help please?
