Connection gone bad again
danbottomburp
So my connection has gone terrible again, my BQM is
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ac34fd4c9281748e838a5f353a78c05971...
3.0 Upstream channels
14620000037.2705995120 KSym/sec64QAM3
23940000037.0205995120 KSym/sec64QAM4
33260000036.5205995120 KSym/sec64QAM5
42580000036.0205995120 KSym/sec16QAM6
1US_TYPE_STDMA0010
2US_TYPE_STDMA00150
3US_TYPE_STDMA00170
4US_TYPE_STDMA00940
Can a forum team member arrange an engineer visit please?
5 REPLIES 5
Its not a good BQM. Can you post up the Downstream data and network logs as well.
Also have you checked for any “known network faults”
As well as trying the “check service,”Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level.
Hello? can somebody please arrange an engineer?
Was with BT for 13 years and had 4 issues in all that time, rock solid connection!
Been with Virgin less than two weeks and had 4 issues already, swapped for faster speed but i have made a huge mistake
This absolutely horrendous connection issues continue and i am going through the ombudsman to get my contract terminated
I need an engineer!!
Post up the missing data as I requested. Then call in if you think you need a Tech visit.
Or a VM person should respond in a few days
You don't need "missing data" to see i have a huge issue
If there is no issue reported on the 0800 number (?) then you do need a Tech visit.
Wait for a VM person to respond on here.
EDIT: I note on your other thread that you were advised there is a known fault with an estimated fix time of 6pm.  I would stick to that thread from now on as its confusing to have 2 going.  Hope they get it sorted soon
