Interista89
Cable issue not fixed from 5 months
Hi Virgin,
It's very difficult these days to contact with you - tried phoned in or online chat - nothing is working.
When someone will look at my problem regarding cable issue? (5 months now)
When I will stop being charge full price for my bill if my current speed is only 25% what I'm paying for? (5 months now)
When I will receive discount for paying for the service that I'm not receiving? (5 months now)
I was very patient during the last 5 months but I was told 4 TIMES by the agents that the problem will be looked at shortly.
Thanks.
Anonymous
Not applicable
Re: Cable issue not fixed from 5 months
what did they say the problem was?
How are you connecting. Wired or wireless?
what device and how are you testing the speed
Interista89
There is a problem with the damaged cable outside my house - apparently it was damaged when council was changing street lights. It doesn't matter how I am connected - speed is reduced by 75% which was confirmed by one engineer who came to check what the problem was.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
If there is a damaged cable affecting your WAN it will show up in a BQM and the Hub stats.
Then
Can you please
