Chatsy
Broadband speed slow, told coverage issue?
I have been experiencing very slow broadband and some periods of non at all. I should have 200 . before lockdown i was often achieving that. Since lockdown it has been considerably slower- 45 ish during the day often.
Since this morning my speed is so slow ethernet and wifi  (and dropped out a few times) I cannot do my work. I called Virgin and had a very unsuccessful phone call where the agent told me her screen said it was a coverage inside my house and she needed to send me a booster that she guaranteed would sort the problem
Could soemone explain the logic. The router hasnt moved, why would my I suddenly require a booster when i have not previously. I am not at all confident that this will fix the problem
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Re: Broadband speed slow, told coverage issue?
What is a wired connection like?
Check you’re also not being charged for the booster as well.
Chatsy
Wired connection is slow too, the agent said the booster would still help
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
What speeds do you get wired?
