  • 12
andrewbakes2019
Message 1 of 11
Broadband slower after upgrade to 500mbps
was on 350mps upgraded to the VIP package today and now speeds are slower should be getting 500mbps
Cable Modem Status
Item Status Comments
298750000
Locked
Ranged Upstream Channel (Hz)
32599976
Locked
Provisioning State
Online
1 298750000 7.8 38 256 qam 21
2 138750000 9 40 256 qam 1
3 146750000 9 40 256 qam 2
4 154750000 8.8 40 256 qam 3
5 162750000 9.5 40 256 qam 4
6 170750000 9.5 38 256 qam 5
7 178750000 9.4 40 256 qam 6
8 186750000 9.3 40 256 qam 7
9 194750000 9 40 256 qam 8
10 202750000 8.8 38 256 qam 9
11 210750000 8.5 38 256 qam 10
12 218750000 8.5 38 256 qam 11
13 226750000 8.4 38 256 qam 12
14 234750000 8.3 38 256 qam 13
15 242750000 8.3 38 256 qam 14
16 250750000 8.1 38 256 qam 15
17 258750000 8 38 256 qam 16
18 266750000 8 38 256 qam 17
19 274750000 7.8 38 256 qam 18
20 282750000 7.6 40 256 qam 19
21 290750000 7.9 38 256 qam 20
22 306750000 7.5 38 256 qam 22
23 314750000 7.6 38 256 qam 23
24 322750000 7.9 38 256 qam 24
1 Locked 38.9 6 0
2 Locked 40.3 5 0
3 Locked 40.3 5 0
4 Locked 40.3 0 0
5 Locked 40.3 4 0
6 Locked 38.9 3 0
7 Locked 40.3 4 0
8 Locked 40.3 3 0
9 Locked 40.3 6 0
10 Locked 38.9 5 0
11 Locked 38.6 5 0
12 Locked 38.9 5 0
13 Locked 38.9 5 0
14 Locked 38.6 5 0
15 Locked 38.9 6 0
16 Locked 38.9 4 0
17 Locked 38.6 4 0
18 Locked 38.6 6 0
19 Locked 38.9 5 0
20 Locked 40.3 5 0
21 Locked 38.9 6 0
22 Locked 38.9 5 0
23 Locked 38.9 5 0
24 Locked 38.9 0 0
1 32599976 4.275 5120 16 qam 12
2 25799937 4.125 5120 16 qam 13
3 39399996 4.275 5120 16 qam 11
4 46199959 4.275 5120 16 qam 10
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
9873254k;fg87dsfd;kf
SFID 6183
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 5158
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
  • 19.28K
  • 1.68K
  • 4.22K
Message 2 of 11
Re: Broadband slower after upgrade to 500mbps
the downstream power levels at the top end of the tolerance, would make sure all white (coax) connections are finger tight, a possibility might need a tech visit this can be arranged via the forum staff
Click to learn more about VIP
Use Kudos to say thanks
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 3 of 11
How are you connecting wired or wirelessly?
  • 12
andrewbakes2019
Message 4 of 11
iv tried both it seems when the poweline adapter is connected i got from vm halfs the speeds taken that out and get 456 up 35 down now
  • 931
  • 43
  • 118
happywithmy350
Well-informed
Message 5 of 11
You should mark your last comment as helpful as that's the solution. I recall after reading that I used to get the same problem It was down to the wiring more than the adapters but I had to swap them out for a loooooooooooooong piece of Cat6
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 6 of 11
Powerline adapters will affect speeds as they are half duplex and are affected by the amount of noise on your electrical mains. so i wouldn't expect much more than 15 to 25% of the powerline's adverted speed.
I have seen some decent powerlines provide actual speeds of over 400Mbps, but the powerlines were tested in the same room which kind of defeats the point.
  • 931
  • 43
  • 118
happywithmy350
Well-informed
Message 7 of 11
I've had 350mbps speeds over a pair of 1200Mbps plugs - with one upstairs and one down stairs - until I had a car charger put in and then it all went to pot
  • 4.6K
  • 309
  • 768
Roger_Gooner
Superstar
Message 8 of 11
I still don't think that things are quite right. Not only are the downstream power levels on the high side, having four upstream 16QAM channels may well make reliable 35Mbps upload speeds difficult.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 947
  • 23
  • 140
shawty1984
Rising star
Message 9 of 11
I have four upstreams at 16QAM and always get full 35+Mbps.
  • 73
  • 17
Gary333
Dialled in
Message 10 of 11
Lots of houses have separate rings for left and right side of the house rather than the traditional upstairs / downstairs. This can mean your upstairs sockets if above or on same side could perform much better than other sockets downstairs but on the other side of the house.
