ecsrobin
Broadband dropped from 200mb to 30mb
The last few weeks I've noticed a drop in internet speeds at home from 210mb to around 30/40mb and sunday evenings its quite common now to have intermitent internet.
Nearly everything is hard wired from the hub3 via cat6 cables except for phones ive got some data from the router if someone can assist.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
298750000
0
37
256 qam
21
2
322750000
0
37
256 qam
24
3
314750000
0.2
37
256 qam
23
4
306750000
0
37
256 qam
22
5
290750000
-0.2
37
256 qam
20
6
282750000
0.2
37
256 qam
19
7
274750000
0.2
37
256 qam
18
8
266750000
0
37
256 qam
17
9
258750000
0
37
256 qam
16
10
250750000
0.5
37
256 qam
15
11
242750000
0.5
37
256 qam
14
12
234750000
0.5
37
256 qam
13
13
226750000
0.5
37
256 qam
12
14
218750000
1
37
256 qam
11
15
210750000
1.4
37
256 qam
10
16
202750000
1.4
37
256 qam
9
17
194750000
1.5
37
256 qam
8
18
186750000
1.7
37
256 qam
7
19
178750000
1.9
37
256 qam
6
20
170750000
2
37
256 qam
5
21
162750000
2.2
37
256 qam
4
22
154750000
2.2
37
256 qam
3
23
146750000
2.2
37
256 qam
2
24
138750000
2.5
37
256 qam
1
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
246
0
2
Locked
37.3
952
0
3
Locked
37.3
455
0
4
Locked
37.3
308
0
5
Locked
37.3
187
0
6
Locked
37.6
90
0
7
Locked
37.3
60
0
8
Locked
37.3
75
0
9
Locked
37.3
49
0
10
Locked
37.6
48
0
11
Locked
37.3
56
0
12
Locked
37.3
54
0
13
Locked
37.3
38
0
14
Locked
37.3
28
0
15
Locked
37.3
38
0
16
Locked
37.6
33
0
17
Locked
37.6
45
0
18
Locked
37.6
198293
0
19
Locked
37.3
2447163
119055
20
Locked
37.6
15783
79697
21
Locked
37.6
2442938
685855
22
Locked
37.6
1764061
154964
23
Locked
37.3
256073
138244
24
Locked
37.6
1878361
1200477
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
48.3
5120
64 qam
6
2
60300000
47
5120
64 qam
5
3
39400000
49
5120
64 qam
8
4
46200000
48.8
5120
64 qam
7
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
2019-01-13 22:30:35.00
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-13 22:36:34.00
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-14 13:19:02.00
Error
2019-01-14 13:24:25.00
Warning!
2019-01-14 20:43:15.00
Error
2019-01-14 20:58:21.00
Warning!
2019-01-15 00:25:22.00
Error
2019-01-15 00:49:47.00
Warning!
2019-01-15 02:16:25.00
Error
2019-01-15 04:07:32.00
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 13:58:10.00
critical
2019-01-15 16:41:56.00
Warning!
2019-01-16 14:04:34.00
critical
2019-01-16 15:50:21.00
Warning!
2019-01-17 19:15:52.00
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 19:15:53.00
Warning!
2019-01-18 10:21:35.00
Error
2019-01-18 11:40:23.00
Warning!
2019-01-18 17:00:35.00
Warning!
2019-01-18 17:00:37.00
Warning!
Thanks in advance
  • 2.74K
  • 138
  • 386
jpeg1
Trouble shooter
Re: Broadband dropped from 200mb to 30mb
There's a lot of noise on some of the download channels.
Check that the coax feed to the Hub is tight. If that doesn't help, phone for support.
ecsrobin
Thank you for taking the time to reply. All connections have been checked both at the wall and at the hub but still the speeds are low.
  • 2.74K
  • 138
  • 386
jpeg1
Trouble shooter
Then call customer support on 150.
