  • 14
michael095
Message 1 of 14
Broadband download speed very slow
I have just upgraded my Broadband from Vivid 200 to Vivid 350 but have noted that my broadband download speed is only a fraction of what it should be:
Ping 158ms
14.07Mbs download
21Mbs upload
I was expecting far better than this. Rebooted the router and still the same. Also checked the router settings for any obvious anomalies and all appear OK. I think this is something for the Tech guys to resolve back at Virgin Media.
  • 7.31K
  • 761
  • 1.14K
Legend
Message 2 of 14
Re: Broadband download speed very slow
Are those numbers by ethernet connection or wifi.  Have you tried a pinhole reset of the router?
  • 14
michael095
Message 3 of 14
Ethernet cable connected to router. Speed test carried out via Internet. No I have not done a pin hole reset of router, but I will do this now. Might be some time before I am back to reply on outcome of this.
  • 14
michael095
Message 4 of 14
Hub 3.0 has rebooted and is now initialising. Carried out another Broadband speed test via Broadband.co.uk and results remain similar as before.
19.57 Mb download
7.51MB up
31ms Ping
This cannot be the extent on Vivid 350 and do think something at Virgin Media has not been correctly set during the upgrade. I have had this same situation before when I upgraded to Vivid 200 and Virgin Media did something via their control hub when I called them and after a while I got better download speeds. I was getting a max 120Mbs but normally in the range of 80 to 100Mbs for Vivid 200. Now Im getting much, much less.
  • 7.31K
  • 761
  • 1.14K
Legend
Message 5 of 14
19.57 Mb download
7.51MB up
31ms Ping
Sorry this will sound a bit Noddy - you did push the pin in firmly till it "stops" and hold for a timed (not guessed) 30 seconds and then add a few – and didn’t turn it off.?  Sometimes it doesnt reset itself properly.
But It t wouldnt be the first time VM "forgot" to press the 350 upgrade button for its customers.  You can look in your config file on the Hub settings and see what your max connection speed is set to.
  • 12.69K
  • 970
  • 2.88K
Message 6 of 14
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
also post the info from configuration
____________________
Tony
  • 14
michael095
Message 7 of 14
Downstream:
12990000001.237256 qam21
23230000000.937256 qam24
33150000001.237256 qam23
4307000000137256 qam22
52910000001.237256 qam20
62830000000.737256 qam19
72750000000.537256 qam18
8267000000137256 qam17
92590000001.437256 qam16
102510000001.538256 qam15
112430000001.537256 qam14
122350000002.237256 qam13
132270000002.537256 qam12
142190000002.538256 qam11
15211000000338256 qam10
162030000003.238256 qam9
171950000003.538256 qam8
18187000000438256 qam7
19179000000438256 qam6
201710000004.338256 qam5
211630000004.538256 qam4
221550000004.938256 qam3
231470000004.838256 qam2
241390000005.338256 qam1
1Locked37.650
2Locked37.6140
3Locked37.650
4Locked37.350
5Locked37.6160
6Locked37.6140
7Locked37.380
8Locked37.6110
9Locked37.650
10Locked38.600
11Locked37.600
12Locked37.660
13Locked37.630
14Locked38.970
15Locked38.630
16Locked38.650
17Locked38.650
18Locked38.640
19Locked38.650
20Locked38.900
21Locked38.600
22Locked38.660
23Locked38.950
24Locked38.600
Upstream
13020000043.8512064 qam2
23680000044512064 qam1
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxl35016u-b.cm
SFID14140
Max Traffic Rate402500000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID14139
Max Traffic Rate22010000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
  • 12.69K
  • 970
  • 2.88K
Message 8 of 14
nothing wrong there - try a test in modem mode if you have not already - test on speedtest.net
Tony
  • 14
michael095
Message 9 of 14
Tested again in Modem Mode via Speednet.net and figures almost the same. Ping 8ms Down 21.76 and up 21.3. Router pin holed reset with button pressed in excess of 30 seconds and router allowed to reboot. No change.
  • 14
michael095
Message 10 of 14
Speedtest.net I meant.
