  • 31
Jackboyo
Message 1 of 5
Broadband disconnecting, not usable
Been having a problem for the past few days.
I have noticed that the broadband seems to disconnect every hour and having great trouble linking to some websites.
run an internet monitor from a website and it is showing that there is an outage roughly every 45 minutes.
Checked the Network log on my hub 3 and that seems to be full of errors for the last two days as follows. Hope that someone can fathom this out, driving me mad.
BTW based in Swansea
30/01/2019 01:53:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2019 02:10:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2019 09:09:42ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2019 11:21:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2019 13:05:57ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2019 17:02:14ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2019 17:24:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 13:47:58Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:7criticalRegistration RSP rejected message syntax error;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:7criticalRegistration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:7ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:7criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:53criticalRegistration RSP rejected message syntax error;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:53criticalRegistration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:53ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:22:53criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 14:23:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2019 15:27:24Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 31
Jackboyo
Message 2 of 5
Re: Broadband disconnecting, not usable
I've also run an Internet connection monitor over the last 12 hours and this is what i get.
Response delay (avg/max)
195.11ms/2827.00ms
Test duration
12h 39m 2s 533ms
Requests period (avg/max)
0.540s/47.1s
Uptime
98.0022%
Downtime
15m 28s 406ms
Outages
24
Outages log
2019-02-01 11:20:19: connection is up (after 45.9s of downtime)
2019-02-01 11:19:33: request failed
2019-02-01 10:50:32: connection is up (after 58.3s of downtime)
2019-02-01 10:50:10: request failed
2019-02-01 10:20:22: connection is up (after 49.0s of downtime)
2019-02-01 10:19:33: request failed
2019-02-01 09:50:22: connection is up (after 48.9s of downtime)
2019-02-01 09:49:33: request failed
2019-02-01 09:20:25: connection is up (after 12.1s of downtime)
2019-02-01 09:20:13: request failed
2019-02-01 08:50:24: connection is up (after 12.2s of downtime)
2019-02-01 08:50:12: request failed
2019-02-01 08:20:21: connection is up (after 10.7s of downtime)
2019-02-01 08:20:10: request failed
2019-02-01 07:50:21: connection is up (after 10.4s of downtime)
2019-02-01 07:50:11: request failed
2019-02-01 07:20:43: connection is up (after 31.1s of downtime)
2019-02-01 07:20:12: request failed
2019-02-01 06:50:44: connection is up (after 32.1s of downtime)
2019-02-01 06:50:12: request failed
2019-02-01 06:20:22: connection is up (after 10.7s of downtime)
2019-02-01 06:20:12: request failed
2019-02-01 05:50:22: connection is up (after 9.2s of downtime)
2019-02-01 05:50:12: request failed
2019-02-01 05:20:22: connection is up (after 10.2s of downtime)
2019-02-01 05:20:11: request failed
2019-02-01 04:50:24: connection is up (after 10.1s of downtime)
2019-02-01 04:50:14: request failed
2019-02-01 04:20:43: connection is up (after 32.1s of downtime)
2019-02-01 04:20:11: request failed
2019-02-01 03:50:24: connection is up (after 10.1s of downtime)
2019-02-01 03:50:14: request failed
2019-02-01 03:20:24: connection is up (after 11.1s of downtime)
2019-02-01 03:20:13: request failed
2019-02-01 02:50:45: connection is up (after 32.1s of downtime)
2019-02-01 02:50:12: request failed
2019-02-01 02:20:22: connection is up (after 10.1s of downtime)
2019-02-01 02:20:12: request failed
2019-02-01 01:50:44: connection is up (after 33.1s of downtime)
2019-02-01 01:50:11: request failed
2019-02-01 01:20:26: connection is up (after 11.7s of downtime)
2019-02-01 01:20:14: request failed
2019-02-01 00:50:22: connection is up (after 9.6s of downtime)
2019-02-01 00:50:12: request failed
2019-02-01 00:20:23: connection is up (after 10.1s of downtime)
2019-02-01 00:20:13: request failed
2019-02-01 00:09:00: connection is up (after 417.7s of downtime)
2019-02-01 00:02:03: request failed
I first reported this over 2 years ago, with the connection dropping and was told that there is nothing wrong with the broadband
  • 5.72K
  • 627
  • 893
Hero
Message 3 of 5
Set up a BQM to get 24/7 real time monitoring and see how its looking on there.
  • 31
Jackboyo
Message 4 of 5
Thinkbroadband is one of the sites I cannot get onto. Tried last night and still not able
  • 14.59K
  • 432
  • 46
Moderator (Retired) Ralph_R
Moderator (Retired)
Message 5 of 5
Hi Jackboyo,
Is the connection wired or wireless and the disconnection problems/site access happening across more than device?
Checking your connection I can see that your upstream power levels are borderline high and this could be a factor, though doesn't really explain why some web sites and not others would be accessible.
Kind rgds
Ralph_R
Forum Moderator
