  • 8
nikhilpshah
Message 1 of 15
Broadband connection falls every night between 11:25 pm and midnight
Hello,
I have been observing this issue for a long time (almost 6 months now). My internet connection drops to nothing at night between 11: 25 and midnight. I have to disconnect and connect to the wireless router every 3 to 4 mins in this time. And this happens on all my devices.
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 2 of 15
Re: Broadband connection falls every night between 11:25 pm and midnight
Does it happen on devices wired directly to the Hub, you will need to test this to determine if it is a VM local circuit issue or a wireless issue
  • 8
nikhilpshah
Message 3 of 15
Yes it happens even when it is wired. My TV wired broadband stops working
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 4 of 15
Odd, this is something I would suspect from a wireless connection, wired less so.
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.0.1
Don't log in, click the Router Status button
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, but do obscure personal information like your WAN IP address.
  • 8
nikhilpshah
Message 5 of 15
Channel           Frequency (Hz)           Power (dBmV) SNR (dB)         Modulation     Channel ID
1          299000000      -1         37        256 qam          21
2          323000000      -0.7      38        256 qam          24
3          315000000      -0.7      38        256 qam          23
4          307000000      -1         38        256 qam          22
5          291000000      -0.9      37        256 qam          20
6          283000000      -0.7      38        256 qam          19
7          275000000      -1         38        256 qam          18
8          267000000      -0.7      38        256 qam          17
9          259000000      -0.5      38        256 qam          16
10        251000000      -0.7      38        256 qam          15
11        243000000      -1         37        256 qam          14
12        235000000      -0.2      38        256 qam          13
13        227000000      0          38        256 qam          12
14        219000000      0          38        256 qam          11
15        211000000      0          38        256 qam          10
16        203000000      0          38        256 qam          9
17        195000000      0.2       38        256 qam          8
18        187000000      0.5       37        256 qam          7
19        179000000      0.5       37        256 qam          6
20        171000000      0.5       37        256 qam          5
21        163000000      0.4       38        256 qam          4
22        155000000      0.5       37        256 qam          3
23        147000000      0.7       38        256 qam          2
24        139000000      0.7       37        256 qam          1
Channel           Locked Status RxMER (dB)     Pre RS Errors   Post RS Errors
1          Locked 37.3     526      4
2          Locked 38.6     384      0
3          Locked 38.6     305      13
4          Locked 38.6     231      0
5          Locked 37.6     228      0
6          Locked 38.6     338      0
7          Locked 38.6     210      13
8          Locked 38.6     238      32
9          Locked 38.6     285      12
10        Locked 38.6     218      1
11        Locked 37.6     164      0
12        Locked 38.9     241      0
13        Locked 38.6     184      13
14        Locked 38.9     144      0
15        Locked 38.6     179      0
16        Locked 38.6     168      0
17        Locked 38.9     177      0
18        Locked 37.6     158      0
19        Locked 37.6     193      0
20        Locked 37.6     141      6
21        Locked 38.9     192      0
22        Locked 37.6     127      12
23        Locked 38.6     176      26
24        Locked 37.6     119      0
Channel           Frequency (Hz)           Power (dBmV) Symbol Rate (ksps)     Modulation     Channel ID
1          46200000        45.5     5120    64 qam            1
2          25800000        45        5120    64 qam            4
3          32600000        45.5     5120    64 qam            3
4          39400000        45.5     5120    64 qam            2
Channel           Channel Type  T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
1          ATDMA            0          0          5          0
2          ATDMA            0          0          3          0
3          ATDMA            0          0          12        0
4          ATDMA            0          0          10        0
Time    Priority Description
2019-01-02 23:24:22.00         Error    DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-03 11:51:51.00         Error    DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-03 11:51:51.00         notice  DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-04 15:48:40.00         critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-07 09:10:46.00         Error    DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-07 10:48:17.00         critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-07 21:54:15.00         Error    DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-08 08:39:12.00         critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-08 09:02:18.00         Error    DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-08 10:37:48.00         Error    DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-08 10:37:48.00         notice  DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-08 22:49:51.00         critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 06:13:40.00         Error    DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 18:42:46.00         critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 18:43:06.00         Error    DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-13 02:59:59.00         critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-13 04:05:11.00         Error    DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-13 07:12:36.00         Error    DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-13 07:12:36.00         notice  DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 22:51:31.00         critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 6 of 15
There is not a lot amiss in the stats, there are quite a few T3 errors in the tally counters but only a couple in the logs. This could be a historical build up in the counters and rebooting the Hub will clear them so you can keep an eye on them.
I would start a Broadband Quality Monitor to get a more detailed picture on what is happening with the local circuit.
It will be worth checking the TV for any enabled power saving settings and any scheduled updates
  • 8
nikhilpshah
Message 7 of 15
Is there anything I need to do from my side?
What and when will I get it rectified?
  • 8
nikhilpshah
Message 8 of 15
I guess the issue is not resolved yet.
Any help is much appreciated.
  • 4.46K
  • 302
  • 748
Roger_Gooner
Community elder
Message 9 of 15
Do any of your neighbours have the same problem?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 8
nikhilpshah
Message 10 of 15
I don't know.. never asked about it.
