  • 10
janojano
Message 1 of 11
Broadband Speed
Hi all
I have been trying to do the online chat for a while but no luck. I want someone to look at my broadband. It is slow all the time and keeps dropping out I have a super hub 2. I have checked my end powered off and restarted many times but i keeps doing it, Wired and wifi drops, I get about 44mb to 60mb download max speed. I pay for 200mb. My xbox is wired and that used to get 200mb every time believe it or not but now again today 50mb.
I need someone to check my line or do i need a new hub?
Help in this matter would be great
  • 10.15K
  • 898
  • 2.17K
Message 2 of 11
Re: Broadband Speed
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, but do obscure personal information like your WAN IP address.
  • 10
janojano
Message 3 of 11
Re: Broadband Speed
ownstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)258750000234750000242750000250750000266750000274750000282750000290750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID41235678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-2.56-2.40-2.32-2.53-2.69-2.68-3.31-3.63
RxMER (dB)38.2637.6436.6135.6038.6138.6138.2638.26
Pre RS Errors62514328741476290314305967
Post RS Errors3079432841003290314305965
  • 10
janojano
Message 4 of 11
Re: Broadband Speed
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID18N/AN/A19
Frequency (Hz)39400000N/AN/A32600000
Ranging StatusSuccessOtherOtherSuccess
Modulation16QAMN/AN/A16QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)41.25N/AN/A41.25
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
T4 Timeouts0000
  • 10
janojano
Message 5 of 11
Re: Broadband Speed
Network LogFirst TimeLast TimePriorityError NumberDescription10/08/2017 17:17:33 GMT10/08/2017 17:17:33 GMTWarning (5)66050310Auth Success - Web login successful.10/08/2017 16:49:28 GMT10/08/2017 16:49:28 GMTError (4)68010302DHCP WAN IP - ##########10/08/2017 16:48:42 GMT10/08/2017 16:48:42 GMTWarning (5)66050310Auth Success - Web login successful.10/08/2017 16:48:29 GMT10/08/2017 16:48:29 GMTError (4)68000407TOD establishedTime Not EstablishedTime Not EstablishedCritical (3)82000200No Ranging Response received - T3 time-outTime Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully10/08/2017 16:47:01 GMT10/08/2017 16:47:01 GMTWarning (5)66050310Auth Success - Web login successful.10/08/2017 16:30:43 GMT10/08/2017 16:30:43 GMTWarning (5)66050310Auth Success - Web login successful.10/08/2017 16:05:51 GMT10/08/2017 16:05:51 GMTWarning (5)66050310Auth Success - Web login successful.10/08/2017 16:05:44 GMT10/08/2017 16:05:44 GMTError (4)68010100DHCP RENEW sent - No response for IPv410/08/2017 13:38:05 GMT10/08/2017 13:38:05 GMTError (4)68010100DHCP RENEW sent - No response for IPv410/08/2017 08:42:46 GMT10/08/2017 08:42:46 GMTError (4)68010100DHCP RENEW sent - No response for IPv409/08/2017 22:52:09 GMT09/08/2017 22:52:09 GMTError (4)68010100DHCP RENEW sent - No response for IPv406/08/2017 22:41:00 GMT06/08/2017 22:41:00 GMTError (4)68010400DHCP REBIND WARNING - Field invalid in response06/08/2017 22:40:02 GMT06/08/2017 22:40:02 GMTError (4)68010100DHCP RENEW sent - No response for IPv406/08/2017 22:39:07 GMT06/08/2017 22:39:07 GMTError (4)68010100DHCP RENEW sent - No response for IPv406/08/2017 22:37:16 GMT06/08/2017 22:37:16 GMTError (4)68010100DHCP RENEW sent - No response for IPv406/08/2017 22:33:35 GMT06/08/2017 22:33:35 GMTError (4)68010100DHCP RENEW sent - No response for IPv406/08/2017 22:26:12 GMT06/08/2017 22:26:12 GMTError (4)68010100DHCP RENEW sent - No response for IPv406/08/2017 22:11:27 GMT06/08/2017 22:11:27 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 10.15K
  • 898
  • 2.17K
Message 6 of 11
Re: Broadband Speed
Stats look fine.
I would start a Broadband Quality Monitor to get a deeper insight on your connection is performing. You will need to enable Respond to ICMP Echo Requests in the Hub's GUI advanced section.
It would be worth trying another ethernet cable just to check it has not gone bad.
Do you experience the poor speeds all the time or just during the evenings?
A VM Forum Team member should pick up the thread in about a week and will take a closer look at your connection wuth their diagnostic tools.
  • 10
janojano
Message 7 of 11
Re: Broadband Speed
Drop out could be anytime, wifi or wired. Cable changed last week.
"You will need to enable Respond to ICMP Echo Requests in the Hub's GUI advanced section."  trying to find this setting but can't see it.
  • 68
  • 22
Cylinderman
Dialled in
Message 8 of 11
Re: Broadband Speed
Hi Janojano
got the same problems here! just done 3 speed checks and got downloads of 75-98 and uploads of 10-13. I'm also paying for 200, been on Virgins web site for a status check and it says nothing wrong. Going to call now and see what is going off again, will let you know the result..
  • 10.15K
  • 898
  • 2.17K
Message 9 of 11
Re: Broadband Speed
Log Into the Hub
Click Advanced Settings
Scroll Down to the very bottom to the Tools header.
Click on ping and tick the bottom tickbox and apply
  • 10
janojano
Message 10 of 11
Re: Broadband Speed
28mb Download
8.7mb upload
Not bad as I'm paying for 200mb :-(  It's just not right and I don't understand why it has dropped so much
