mwg1
Broadband Speed Check
Hi There,
I got my virgin broadband on 15th evening. I have signed up for 100Mbps. But my speed is quite low as below. Could you please check all the necessary information provided below as suggested in community.virginmedia.com/Broadband-Speed-Check
12990000002.738256 qam21
23230000002.538256 qam24
33150000002.738256 qam23
43070000002.738256 qam22
52910000002.538256 qam20
62830000002.538256 qam19
72750000002.237256 qam18
8267000000236256 qam17
9259000000236256 qam16
102510000002.236256 qam15
112430000002.436256 qam14
122350000002.536256 qam13
132270000002.536256 qam12
142190000002.536256 qam11
152110000002.736256 qam10
16203000000336256 qam9
171950000003.437256 qam8
181870000003.536256 qam7
191790000003.736256 qam6
20171000000437256 qam5
211630000004.137256 qam4
221550000004.138256 qam3
231470000004.438256 qam2
241390000004.538256 qam1
1Locked38.6130
2Locked38.6130
3Locked38.980
4Locked38.670
5Locked38.6570
6Locked38.660
7Locked37.6160
8Locked36.6170
9Locked36.6140
10Locked36.660
11Locked36.6130
12Locked36.6110
13Locked36.370
14Locked36.380
15Locked36.3170
16Locked36.6120
17Locked37.380
18Locked36.390
19Locked36.6110
20Locked37.3240
21Locked37.6210
22Locked38.6170
23Locked38.660
24Locked38.600
15370000045.5512064 qam18
24620000045512064 qam19
36030000046512064 qam17
43940000044.8512064 qam20
3ATDMA0000
4ATDMA001
1970-01-01 00:01:39.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:02:23.00criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:03:03.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:03:47.00criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 14:41:48.00noticeSW Download INIT - Via Config file
2019-01-15 14:48:11.00ErrorDisruption during SW download - Power Failure
2019-01-15 14:48:15.00noticeSW Download INIT - Via Config file
2019-01-15 14:50:10.00noticeSW download Successful - Via Config file
2019-01-15 14:55:01.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 14:55:01.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 14:55:02.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 14:55:06.00Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 14:55:17.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-15 14:55:17.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-16 13:26:41.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Thanks & Regards
  • 8.65K
  • 886
  • 1.34K
Re: Broadband Speed Check
Stats look ok to me. How are you testing the speeds - wifi or wired? What device? At speedtest.net?
mwg1
Speed tested with wired to laptop on speedtest.net. Fyi added Hub 3.0 network logs now.
mwg1
Today's wired speed test on speedtest.net is below (56.37mbps). better than yesterday, but much less than expected 100mbps speed. Wired_Speedtest.net_17Jan_2220
23230000002.738256 qam24
4307000000338256 qam22
52910000002.738256 qam20
62830000002.537256 qam19
82670000002.236256 qam17
92590000002.236256 qam16
102510000002.436256 qam15
112430000002.536256 qam14
132270000002.736256 qam12
142190000002.736256 qam11
152110000002.936256 qam10
162030000003.236256 qam9
171950000003.536256 qam8
201710000004.137256 qam5
211630000004.337256 qam4
221550000004.337256 qam3
231470000004.538256 qam2
241390000004.838256 qam1
1Locked38.6210
2Locked38.6190
3Locked38.6230
4Locked38.6160
5Locked38.6990
6Locked37.680
7Locked37.6360
8Locked36.6430
9Locked36.3180
10Locked36.3110
11Locked36.6220
12Locked36.3210
13Locked36.3110
14Locked36.3140
15Locked36.3280
16Locked36.3160
17Locked36.6120
18Locked36.3230
19Locked36.6290
20Locked37.3260
21Locked37.3250
22Locked37.6250
23Locked38.6210
24Locked38.950
15370000045.5512032 qam18
24620000045512032 qam19
36030000045.8512032 qam17
43940000045512032 qam20
2ATDMA0010
3ATDMA0000
4ATDMA0010
Nothing new in after 2019-01-16 13:26:41.00 (pasted in initial post) this in network logs.
mwg1
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Hi Mwg1,
All the stats you've posted look fine. I've tried to check your connection from here but couldn't locate your account. I've just sent you a private message requesting some details.
