  • 39
  • 6
swapshop1
Message 1 of 8
Box open
Lincoln
LN60WD
Box open.
Fix it or have complaints.
Let's not tape it back together this time. Each time a guy comes out, he takes the tape off to do some work then pushed the doors shut. Box eventually opens. It's broken you know. Then someone comes out to tape it up again. Bottom spigot sheered off.
I'm a customer on a new account. Not this one.
  • 39
  • 6
swapshop1
Message 2 of 8
Re: Box open
The box was opened for me as a new customer. So it's been like this since the beginning of April. Clearly it hasn't been reported. There are no good Samaritans. DIY as always! I reported this several years ago. That's when the tape started!
  • 8.6K
  • 883
  • 1.34K
Message 3 of 8
Re: Box open
The number (automated iirc) for reporting street box problems is 0330 333 0444
  • 39
  • 6
swapshop1
Message 4 of 8
Re: Box open
Thank you. But no offence. I've wasted enough of my time. If the TV goes out then I'm having compensation. It's automatically paid I believe. I'll only here for 12 months then off. I'm not going to play the old customer deal scam
I think a mod should be around in a few days to read this. They can sort it then. Unless they don't patrol the forums anymore. Perhaps. Feel free to flag my post for moderation. It might happen quicker.
  • 2.24K
  • 70
  • 101
Message 5 of 8
Re: Box open
Hi swapshop1,
Thank you for your post. I'm sorry to see this.
If you can provide me with the full street address & the cabinets location on the street I can get this reported?
^Martin
  • 39
  • 6
swapshop1
Message 6 of 8
Re: Box open
All sorted.
I had to call up because the engineer BEFORE I joined "reconnected my services" to a phone line that was live for a self install - he should have left it alone. When I was officially connected, the line had the wrong phone number. so after many phone calls, engineer came out and found the actual wire was incorrect according to the db. he swapped the lines BACK, and now i have my ported in number. Who's was the number I was using? well, we didn't make any calls - I don't think so they should be ok.
Anyway - box door re-attached, using the lock and top spigot. It will be ok for another 5 years I guess, unless someone joins and the engineer is sloppy. Or kids play and pull the bottom of the door.
By then, it might be ripped out and true fibre installed? probably re-use the old box!
  • 106
  • 5
  • 23
louis-m
Up to speed
Message 7 of 8
Re: Box open
Another one fully open at:
Elizabeth Street
Corby
Northants
NN17
  • 1.06K
  • 38
  • 51
Message 8 of 8
Re: Box open
Hi there louis-m
Thank you for posting on our community forums and for taking the time to let us know about this.
So that we can report this equipment and arrange for a repair etc. would you be able to give us an approximate location of where the box is on the road please?
Many thanks.
David_Pn
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
