on 08-02-2022 06:51
Morning folks,
Can i ask which speed test people use? Since upgrading to the Hub4 with 1GB broadband i have been trying it out using Speedtest.net via ethernet.
One minute it gives 800mbps next it will be 450mbps.
No pre or post RS errors and the BQM looks fine.
on 08-02-2022 17:16
VM used to advise initiating four simultaneous downloads and adding te speeds together, then they advised Speedtest by Ookla. They have now introduced SamKnows RealSpeed which as previously stated only works in router mode (when it actually works), but in my experience it doesnt.
Samknows Speedtest works regardless of modem or router mode and funnily enough any test i did there yesterday or today only gives 750Mbps so that could be congestion on the test servers.
on 09-02-2022 10:39
@m00g wrote:VM used to advise initiating four simultaneous downloads and adding te speeds together, then they advised Speedtest by Ookla. They have now introduced SamKnows RealSpeed which as previously stated only works in router mode (when it actually works), but in my experience it doesnt.
There is a difference between the two tests.
The Realspeed is a client built into the Hub's firmware by VM, hence it only works in Router mode. It will not work for anyone who uses modem mode, e.g. myself.
The Speedtest works for anyone, as it's browser based and not linked to any Hub.
on 09-02-2022 10:41
@clarkey39 wrote:OK. I have now tried it via safe mode on my laptop and via ethernet. <snip>
Okay, that's progress. At least you know something on the windows software side is slowing things down. Just one question, are you sure your kit is capable of getting the full ~950mb over ethernet ?
on 09-02-2022 12:01
I managed to get @900mbps using this laptop.
Is that the most i can ever hope for?
