prezerka
  • 16
Message 1 of 9
Back again, Slow 1 Gig wifi. Issue still not sorted
Came off the phone to VM hub 4 specialist team yesterday expecting the issue of the slow broadband to be sorted after the agent insured me they haves sent a booster signal. This signal restarted my router, and that was pretty much it.
The 'realspeed' test on the samknows website shows speed of 1044mbps to router vs 116mbps to computer over wifi when this device is the ONLY device connected over wifi. I also have a PS5 that is connected Via ethernet TP Link powerline and still only able to get 150.2mbps(download) and 25.1mbps(upload). And these results do not change a considerable amount test after test.
I will follow up with the router status and a BQM, would appreciate it someone could decipher it and tell me what is wrong with my broadband so I can raise the issue again to virgin media who seems reluctant to help.
prezerka
  • 16
Message 2 of 9
Re: Back again, Slow 1 Gig wifi. Issue still not sorted
Cable Modem Status
Item Status Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview Downstream Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
prezerka
  • 16
Message 3 of 9
3.0 Downstream channels
30 402750000 6.199997 38.983261 QAM256 30
1 138750000 6.699997 37.355988 QAM256 1
2 146750000 6.400002 37.355988 QAM256 2
3 154750000 6.300003 37.355988 QAM256 3
4 162750000 6.300003 37.355988 QAM256 4
5 170750000 6.199997 37.636276 QAM256 5
6 178750000 6.199997 37.636276 QAM256 6
7 186750000 6.199997 37.636276 QAM256 7
8 194750000 6.000000 37.636276 QAM256 8
9 202750000 5.699997 37.636276 QAM256 9
10 210750000 5.400002 37.636276 QAM256 10
11 218750000 5.300003 37.636276 QAM256 11
12 226750000 5.000000 37.636276 QAM256 12
13 234750000 4.800003 37.636276 QAM256 13
14 242750000 4.500000 37.355988 QAM256 14
15 250750000 4.400002 37.636276 QAM256 15
16 258750000 5.800003 37.636276 QAM256 16
17 266750000 6.199997 37.636276 QAM256 17
18 274750000 6.800003 37.636276 QAM256 18
19 282750000 7.199997 38.605377 QAM256 19
20 290750000 7.500000 38.605377 QAM256 20
21 298750000 7.699997 38.605377 QAM256 21
22 306750000 7.500000 38.605377 QAM256 22
23 314750000 7.300003 38.605377 QAM256 23
24 322750000 7.099998 38.605377 QAM256 24
25 330750000 7.300003 38.605377 QAM256 25
26 370750000 5.900002 38.983261 QAM256 26
27 378750000 6.000000 38.605377 QAM256 27
28 386750000 6.400002 38.983261 QAM256 28
29 394750000 6.300003 38.605377 QAM256 29
31 410750000 6.099998 38.983261 QAM256 31
30 Locked 0 0 0
1 Locked 374440594 0 0
2 Locked 485485844 1 0
3 Locked 225622677 4 0
4 Locked 378902468 0 0
5 Locked 374264799 0 0
6 Locked 376689597 1 0
7 Locked 375463053 0 0
8 Locked 197548593 0 0
9 Locked 198349202 0 0
10 Locked 197494316 2 0
11 Locked 194774871 0 0
12 Locked 196959670 0 0
13 Locked 195830496 0 0
14 Locked 190959952 0 0
15 Locked 192891784 0 0
16 Locked 191741479 0 0
17 Locked 190679985 0 0
18 Locked 193335419 0 0
19 Locked 192812332 0 0
20 Locked 159032184 0 0
21 Locked 159500594 0 0
22 Locked 173540108 0 0
23 Locked 192346232 0 0
24 Locked 323177786 0 0
25 Locked 377293174 0 0
26 Locked 373746273 0 0
27 Locked 373559352 0 0
28 Locked 379740445 0 0
29 Locked 377520777 0 0
31 Locked 1200232899 0 0
3.1 Downstream channels
33 86 4K 1680 QAM4096 424
33 Locked 5.7 1245351075 1
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 9
You cannot measure speed over Wi-Fi, it is too unpredictable.
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
prezerka
  • 16
Message 5 of 9
3.0 Upstream channels
1 32600000 42.520599 5120 KSym/sec 64QAM 7
2 39400000 43.020599 5120 KSym/sec 64QAM 6
3 46200000 43.020599 5120 KSym/sec 64QAM 5
4 25800000 42.520599 5120 KSym/sec 64QAM 8
1 US_TYPE_STDMA 0 0 1 0
2 US_TYPE_STDMA 0 0 1 0
3 US_TYPE_STDMA 0 0 1 0
4 US_TYPE_STDMA 0 0 1 0
prezerka
  • 16
Message 6 of 9
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076+voc-b.cm
SFID
45256
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
45255
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
prezerka
  • 16
Message 7 of 9
My Broadband Ping - My graph
prezerka
  • 16
Message 8 of 9
1045 to router.
157 to computer.
Connected to a Cat 5e ethernet cable.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 9
Can you put the PC into 'Safe Mode with Networking' and test again please.
yhen
Leave it in Safe Mode and try with a different ethernet cable.
