  • 154
  • 13
  • 38
techifan
Superfast
Average Latency (ms) showing as a saw tooth shape
Does anyone else have their Average Latency (ms) showing as a saw tooth shape?
I am sure it didn’t used to look like that and was a flat blue band.
BTW, everything works fine, just inquisitive.
  • 4.47K
  • 302
  • 749
Roger_Gooner
Community elder
Re: Average Latency (ms) showing as a saw tooth shape
See mine, it's the ideal.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 154
  • 13
  • 38
techifan
Superfast
So whats causing the saw tooth effect?
  • 4.47K
  • 302
  • 749
Roger_Gooner
Community elder
Can you post some stats. Go to 192.168.0.1 (router mode) or 192.168.100.1 (modem mode), do not log in, click on the link "Check Router Status".
Copy and paste the Downstream, Upstream and Network Logs. Mask any public IP or MAC addresses.
  • 154
  • 13
  • 38
techifan
Superfast
  • 11.8K
  • 1.08K
  • 2.56K
griffin
There is an explanation on the sawtooth affect on the Thinkbroadband pages
The sample graph sows the sawtooth in the latency and not in the average latency, but I think the principle holds true, it's just one of those things. If your connection is fine I wouldn't worry about it.
