  • 22
keninho83
Message 1 of 5
Are my power levels a bit low?
Having done a test on my virgin hub 3, does anyone think these readings are signs of a fault? Im sure i read that the power should be between +10 and -6 dbmv and ideally around the +2 area yet mines are dangerously close or bang on the limits in some cases
1299000000-2.738256 qam21
2323000000-1.540256 qam24
3315000000-1.940256 qam23
4307000000-2.440256 qam22
5291000000-3.540256 qam20
6283000000-3.540256 qam19
7275000000-3.740256 qam18
8267000000-3.738256 qam17
9259000000-4.538256 qam16
10251000000-5.438256 qam15
11243000000-5.538256 qam14
12235000000-538256 qam13
13227000000-538256 qam12
14219000000-5.538256 qam11
15211000000-5.738256 qam10
16203000000-5.738256 qam9
17195000000-5.738256 qam8
18187000000-5.538256 qam7
19179000000-5.738256 qam6
20171000000-5.938256 qam5
21163000000-638256 qam4
22155000000-638256 qam3
23147000000-638256 qam2
24139000000-5.738256 qam1
  • 10.41K
  • 655
  • 1.38K
jb66
Message 2 of 5
Re: Are my power levels a bit low?
They are borderline low, do you have an attenuator on your hub?
  • 22
keninho83
Message 3 of 5
No, nothing mate
  • 10.41K
  • 655
  • 1.38K
jb66
Message 4 of 5
I guess if it drops to 6.1 you could call up to get a technician.  Your SNR is good so your connection probably will be fine with a slightly low signal
  • 10.32K
  • 281
  • 591
Forum Team (Retired) Emma_E
Message 5 of 5
Hi keninho83,
Welcome to the forums, I am sorry to see you have been having trouble with your connection.
I have taken a look and your upstream power levels are a touch on the high side but nothing that should be causing any issues. The downstream power levels look fine.
How are you finding the connection?
Speak to you soon.
Emma
