  • 15
MrTIMarshall
Message 11 of 19
Re: Appauling Speed & Even More Appauling Chat Response!
Thank you everyone for all your help so far and I do hope that I have addressed the requested information below.
I would also like to not that all speed tests have been done using WiFi in both properties, before moving and our current property.
Downstream
Spoiler
12990000003.438256 qam21
21870000006.340256 qam7
31950000005.838256 qam8
42030000005.538256 qam9
52110000005.138256 qam10
62190000004.938256 qam11
72270000004.938256 qam12
82350000004.537256 qam13
92430000004.338256 qam14
102510000004.338256 qam15
11259000000438256 qam16
12267000000438256 qam17
132750000003.938256 qam18
142830000003.438256 qam19
15291000000338256 qam20
163070000003.738256 qam22
173150000004.438256 qam23
183230000004.437256 qam24
193790000004.938256 qam25
20387000000538256 qam26
213950000004.838256 qam27
22403000000538256 qam28
23411000000538256 qam29
244190000004.638256 qam30
Upstream
Spoiler
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1394000004.575512064 qam10
2258000214.575512064 qam12
3326000094.425512064 qam11
4462000534.575512064 qam9
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
Spoiler
TimePriorityDescription
30/04/2019 19:21:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2019 23:24:0ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 06:59:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 09:19:28ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 12:38:1ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 12:38:1noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 19:11:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2019 09:34:43ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2019 01:46:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2019 01:50:1ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2019 04:09:24ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/05/2019 04:09:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2019 00:34:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2019 21:48:16ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2019 22:28:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/05/2019 13:18:7ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2019 04:48:3ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2019 04:48:3noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2019 03:39:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2019 06:36:29ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 11.74K
  • 778
  • 3.45K
Message 12 of 19
Kay you have HUB3 have you separated out the SSID's for 2.4 and 5Ghz bands?
Check that, try switching OFF Channel optimisation in the Smart Wifi bit of the GUI...
Then set up a BQM
 HERE
 Run it for say 24 hrs, and post the result.
Click to learn more about VIP
Use Kudos to say thanks
  • 15
MrTIMarshall
Message 13 of 19
I have now wired up my PC via ethernet cable and have the BQM running. Do I need to leave my computer on for the 24hr duration or does it ping the router and not my computer so it doesn't matter how my computer connects and whether it is on or not?
  • 9.06K
  • 936
  • 1.42K
Message 14 of 19
pings the Hub - ok to turn pc off
  • 15
MrTIMarshall
Message 15 of 19
I am uncertain what this data shows and UI know it has not been going on for a 24 hour period, but as it is dynamic, I thought it would be useful enough to post
My Broadband Ping - My Virgin Home Broadband Connection
  • 9.06K
  • 936
  • 1.42K
Message 16 of 19
There is an "explanation" page on the thinkbroadband website that details what all the traces mean - its very good.
  • 15
MrTIMarshall
Message 17 of 19
  • 9.06K
  • 936
  • 1.42K
Message 18 of 19
The red blocks are basically indicating when your Hub is disconnected from the network and cant be pinged. Just turn it off for half an hour and then look at the BQM you will see a red block lasing 30 mins
  • 2.78K
  • 139
  • 405
jpeg1
Trouble shooter
Message 19 of 19
The router stats and the BQM plots (apart from the red block when the Hub may have been turned off ?) suggest that your VM feed is normal.  You have a WiFi problem.
As suggested earlier, you cannot transport a WiFi environment from one location to another. Every location is different, there are many factors that affect the signal coverage..
There are a number of changes you can make to improve WiFi coverage, and there are several links to guide you on this page .
