  • 11.38K
  • 254
  • 2.12K
Message 761 of 768
Re: Advice please poor signal and slow speeds stats inside
@Ignition wrote:
Suspect the upstream power is not accurate!
Carl, the OP needs to confirm his Firmware version as this looks (possibly coincidental) the same Floating Point issue that we have had in other "forked" variants previously(and thus currently observed on some current Trial variants)?
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
  • 861
  • 16
  • 133
tommey
Well-informed
Message 762 of 768
Well hopefully I will see some improvements once the 4th of December has been and gone, I will keep this thread updated with hopefully some good news for a change.
This is the poor quality of my Superhub 3 connection Smiley Sad
My Broadband Ping - Vivid 350
- AREA 04 First reported 09/2014 - Fault ticket raised 01/01/15 -    - Review 01/05/15 - Review 12/08/15 - Review 14/10/15 - Review 04/11/15 - Review 15/04/16 - Review 06/07/16 - Review 31/09/16 - Review 30/11/16 - Review 15/02/17 - Review 12/07/17 - Review 20/09/17 - Review 14/06/17 - Review 10/01/18 - Review 25/04/18 - Review 08/08/18 - Review 12/09/18 - Review 05/12/18 - F004670584 << ALMOST 4 YEARS!!!
But with BT Fibre I can actually game without lag Smiley Very Happy
My Broadband Ping - BT FIBRE 80/20
  • 861
  • 16
  • 133
tommey
Well-informed
Message 763 of 768
Yes I am on a trial firmware so stats now make sense, thanks @horseman
  • 861
  • 16
  • 133
tommey
Well-informed
Message 764 of 768
Well this is odd I just received a private message from the mod team stating that my current fault F004670584 has now been reported as resolved by the networks team and I should start to notice an improvement in my broadband speeds.
So what was the letter I received last week?
https://community.virginmedia.com/t5/Speed/Advice-please-poor-signal-and-slow-speeds-stats-inside/m-...
Now if it indeed was fixed surely at 12:21pm on a weekday I should see the full Vivid 350 speeds?
7836217978
7836223267
7836226274
7836228443
7836230716
Out of all the different servers I tried on speedtest only one of them seems to give anything anywhere near Vivid 350 and even that is lower than the max attainable which you would think at this time of day I would see using the other servers listed.
7836233186
And even that one is hit and miss
7836254647
Just for good measure here are a few thinkbroadband speed tests
1543409029654012955-mini
1543409141174210055-mini
1543409184429902255-mini
Well I suppose I should be grateful because these are the best speeds I have seen in 4 years however these tests were done in the middle of a working day so it will be interesting to see what happens between 4pm > 11pm I will try and run a few speed tests however unfortunately I am very busy today.
  • 861
  • 16
  • 133
tommey
Well-informed
Message 765 of 768
They tell me my fault is fixed does my bbq monitor graph show it's fixed?
  • 861
  • 16
  • 133
tommey
Well-informed
Message 766 of 768
Hey Virgin could you perhaps reply?
  • 861
  • 16
  • 133
tommey
Well-informed
Message 767 of 768
Ok so apparently they fixed my utilisation issues back in Sep 2018 however they have now moved me from that CMTS and my issues have returned so it begs the question WHY?
I simply CANNOT get any kind of reply from virgin which is of no surprise so can anyone here please explain why Virgin would move a customer from CMTS SAND12 which I believe this property has been connected to since 2011 to CMTS SAND13 my connection since this change has been aweful and is most certainly suffering from utilisation AGAIN!!!
History of the line
29 Aug 2015 sand12-2-0-cust56
08 Jan 2016 sand12-2-0-cust56
29 Jul 2016 sand12-2-0-cust30
06 Nov 2016 sand12-2-0-cust40
06 May 2017 sand12-2-0-cust40
24 Jan 2018 sand12-2-0-cust40
09 APR 2018 sand12-2-0-cust218
23 NOV 2018 sand12-2-0-cust61
22 JAN 2019 sand13-2-0-cust166
  • 861
  • 16
  • 133
tommey
Well-informed
Message 768 of 768
So still no reply from Virgin here or via pm
Could I perhaps get a reply to my previous pm? and could you also confirm that when I was moved from cmts SAND12 to cmts SAND13 that the over utilisation issue is now back?
Hope to finally start getting some replies from Virgin Media
