  • 36
Dominix
Message 11 of 23
Re: A great request for help.
Thx a lot. Upload stays the same, and there is no problem to stream to any of those 3 servers.
I hope that more ppl will post results.
  • 36
Dominix
Message 12 of 23
Things are getting worse and worse every day.
https://i.imgur.com/o0yGMsj.png
Nobody else would like to help?
  • 45
  • 8
Hoogle
Message 13 of 23
factory reset your hub3
do speed tests again
if still not decent speeds to go your router login page and instead of entering password click check router status and post screenshots of your channel statuses etc
  • 36
Dominix
Message 14 of 23
Hub was replaced to brand new 3 days ago.
same issue right after it was booted up vs previous one I had which was used (refurbished)
also to note I have constant output packet losses
https://imgur.com/a/8f24VCs
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/24...
today im not even able to stream in 4500kbps -_-
https://i.imgur.com/N8YoCb4.png i get around 10%+ of frame drops at this bitrate.
I don't know is network in my area overloaded or something else.
Just as a comparision, this is from April this year, 8000kbps no issues at all:
https://imgur.com/a/QZs2RcP
or later in May:
https://imgur.com/a5xy0Zi
  • 1.61K
  • 80
  • 111
Message 15 of 23
Good Evening Dominix,
Are you having issues with any other online services or is this just with Twitch?
The download and uploads speeds you've notified us of are what we would expect to see on a 350mb package
David_Bn
  • 36
Dominix
Message 16 of 23
Hello David
YT,Mixer,Restream.io etc
About speeds, I don't really think it is as it should.
Upload is what matter most for me at this moment, and it's not even close to what I was able to achieve months ago.
https://www.speedtest.net/result/8219527608
from Aprli when my UP was boosted to 35Mbps
https://www.speedtest.net/result/8422306289
Now.
Also before Quality to twitch servers was always very close to 100, now to every server in EU is 0
speeds are also very very low, and constant packet losses.
Twitch inspector and OBS stats looks like:
https://imgur.com/a/zZJxt2D
As I said before, the reason why I use twitch tools to show my issue is only because Twitch has tools like this, to measure and check is there any problem with stream, network etc
But in my case, if I have problem with twitch, I also have same issue to other streaming services.
Was ok, now not at all.
I have same hardware*, same OBS settings, and its worse every day.
I used powerline adapter before and had no issues at all, now I use CAT6A ethernet cable because powerline is not perfect, still better than Wi-Fi but not as good as just a cable and I have now.
There is something between Virgin and streaming services in my case.
When I plug my phone to PC to do a bandwidth test
https://i.imgur.com/DtSvwco.png
Even that speeds are low, Quality is much higher than fiber, that's not how it suppose to be.
  • 45
  • 8
Hoogle
Message 17 of 23
you still havent posted your router status screenshots for us to see if you have the 35 mbps upload speed increase firmware upgrade or if it is hanging and not installing
  • 36
Dominix
Message 18 of 23
I did already, like 2h ago.
  • 45
  • 8
Hoogle
Message 19 of 23
ah my bad it doesnt look like you have the latest firmware or you have possibly corrupted firmware as mine is different to yours on same 350mbps service.
firmware.PNGThat is all I can think off so try power cycling your router and if that fails the update go into configuration admin settings reload/reboot and do them options not sure if me providing my configuration file would work on your router
  • 12.55K
  • 481
  • 1.12K
Message 20 of 23
Your BQM shows packet loss thats likely the reason.
