on 12-03-2021 21:47
Yet again very slow speeds at night, bqm from last night below along with router logs
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a45434949700d3637a0940c274c6825af646e1c3-12-03-2021
1 | 331000000 | 4.5 | 38 | 256 qam | 25 |
2 | 203000000 | 0.5 | 36 | 256 qam | 9 |
3 | 211000000 | 0.5 | 36 | 256 qam | 10 |
4 | 219000000 | 0.5 | 36 | 256 qam | 11 |
5 | 227000000 | 0.2 | 36 | 256 qam | 12 |
6 | 235000000 | 0.4 | 36 | 256 qam | 13 |
7 | 243000000 | 0.7 | 37 | 256 qam | 14 |
8 | 251000000 | 1.4 | 37 | 256 qam | 15 |
9 | 259000000 | 1.5 | 37 | 256 qam | 16 |
10 | 267000000 | 2 | 36 | 256 qam | 17 |
11 | 275000000 | 2.2 | 37 | 256 qam | 18 |
12 | 283000000 | 2.7 | 37 | 256 qam | 19 |
13 | 291000000 | 3 | 37 | 256 qam | 20 |
14 | 299000000 | 3.7 | 37 | 256 qam | 21 |
15 | 307000000 | 3.7 | 37 | 256 qam | 22 |
16 | 315000000 | 4 | 38 | 256 qam | 23 |
17 | 323000000 | 4.4 | 38 | 256 qam | 24 |
18 | 371000000 | 4.4 | 37 | 256 qam | 26 |
19 | 379000000 | 4.3 | 37 | 256 qam | 27 |
20 | 387000000 | 4.4 | 37 | 256 qam | 28 |
21 | 395000000 | 4.4 | 38 | 256 qam | 29 |
22 | 403000000 | 4.5 | 38 | 256 qam | 30 |
23 | 411000000 | 4.5 | 38 | 256 qam | 31 |
24 | 419000000 | 4.6 | 38 | 256 qam | 32 |
1 | Locked | 38.6 | 65 | 232 |
2 | Locked | 36.6 | 96 | 265 |
3 | Locked | 36.6 | 128 | 223 |
4 | Locked | 36.6 | 157 | 274 |
5 | Locked | 36.6 | 227 | 217 |
6 | Locked | 36.6 | 142 | 235 |
7 | Locked | 37.3 | 132 | 268 |
8 | Locked | 37.3 | 115 | 262 |
9 | Locked | 37.3 | 110 | 307 |
10 | Locked | 36.6 | 170 | 270 |
11 | Locked | 37 | 195 | 229 |
12 | Locked | 37.6 | 167 | 241 |
13 | Locked | 37.6 | 107 | 247 |
14 | Locked | 37.3 | 119 | 252 |
15 | Locked | 37.3 | 82 | 280 |
16 | Locked | 38.6 | 91 | 210 |
17 | Locked | 38.6 | 98 | 208 |
18 | Locked | 37.6 | 64 | 361 |
19 | Locked | 37.6 | 86 | 222 |
20 | Locked | 37.6 | 100 | 233 |
21 | Locked | 38.6 | 73 | 266 |
22 | Locked | 38.6 | 89 | 196 |
23 | Locked | 38.6 | 98 | 196 |
24 | Locked | 38.6 | 106 | 184 |
1 | 39400187 | 44.3 | 5120 | 64 qam | 6 |
2 | 25800000 | 44.3 | 5120 | 64 qam | 8 |
3 | 32600068 | 45.8 | 5120 | 64 qam | 7 |
4 | 46199998 | 45.8 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 26-03-2021 20:19
first test 7.41pm
second test 7.45pm (it was stuck on the upload, the 42.0 was from a previous moments earlier)
3rd BQM, bang on 6.30pm,as shown, it went down, it's almost like someone flicks a switch and down it goes.
We did have two very nice managers (Ian and Anthony) come today as they were in the area, they fully tested the network from the green box, just down our street to the house and inside and found no problems at all, they couldn't do enough to explain what they were testing etc, credit to virgin media, it could well be a possible network issue when more customers use your internet at certain times of day E.G. 6.30pm, needs escalating to the networks team perhaps.
BTW when Anthony had plugged the ethernet cables back into the hub and my 4 port network switch, then tested the hub thru the 4 port switch he said there was loopback connection and was only getting around 370mb, when they had left i unplugged the network switch as instructed to find he had accidently plugged TWO ethernet cables from the hub to the switch instead of one to the network switch and one to my NAS, easy mistake to make i guess.
on 26-03-2021 21:29
from the virgin media speed test,
26/03/2021 21:21:18 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 21:17:27 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 21:17:24 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 21:17:23 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 21:17:23 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 21:15:48 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 21:04:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 21:04:28 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 20:49:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 20:49:12 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 20:09:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 20:09:8 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:54:38 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:54:38 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:54:33 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:36:56 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:36:53 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:36:53 | critical | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:36:37 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2021 19:36:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 26-03-2021 21:32
bqm new one
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1ac1bf2e2fa1a8841d8481e5c003785392e71026
1 | 331000000 | 6.1 | 37 | 256 qam | 25 |
2 | 203000000 | 3.5 | 36 | 256 qam | 9 |
3 | 211000000 | 3.5 | 36 | 256 qam | 10 |
4 | 219000000 | 3.4 | 36 | 256 qam | 11 |
5 | 227000000 | 3.4 | 36 | 256 qam | 12 |
6 | 235000000 | 3.4 | 36 | 256 qam | 13 |
7 | 243000000 | 3.4 | 37 | 256 qam | 14 |
8 | 251000000 | 3.9 | 37 | 256 qam | 15 |
9 | 259000000 | 4 | 37 | 256 qam | 16 |
10 | 267000000 | 4.3 | 36 | 256 qam | 17 |
11 | 275000000 | 4.5 | 37 | 256 qam | 18 |
12 | 283000000 | 4.9 | 37 | 256 qam | 19 |
13 | 291000000 | 5.3 | 37 | 256 qam | 20 |
14 | 299000000 | 5.8 | 37 | 256 qam | 21 |
15 | 307000000 | 5.9 | 37 | 256 qam | 22 |
16 | 315000000 | 6 | 37 | 256 qam | 23 |
17 | 323000000 | 6.1 | 37 | 256 qam | 24 |
18 | 371000000 | 5.9 | 37 | 256 qam | 26 |
19 | 379000000 | 5.8 | 37 | 256 qam | 27 |
20 | 387000000 | 5.6 | 37 | 256 qam | 28 |
21 | 395000000 | 5.6 | 37 | 256 qam | 29 |
22 | 403000000 | 5.8 | 38 | 256 qam | 30 |
23 | 411000000 | 5.6 | 37 | 256 qam | 31 |
24 | 419000000 | 5.9 | 38 | 256 qam | 32 |
1 | Locked | 37.6 | 8429280 | 5355 |
2 | Locked | 36.3 | 88801402 | 1357184 |
3 | Locked | 36.3 | 105627519 | 2844028 |
4 | Locked | 36.3 | 111183493 | 3686021 |
5 | Locked | 36.6 | 104044790 | 2549859 |
6 | Locked | 36.3 | 83495733 | 1008144 |
7 | Locked | 37.3 | 69038248 | 497396 |
8 | Locked | 37.3 | 61347289 | 309055 |
9 | Locked | 37.3 | 68525022 | 466677 |
10 | Locked | 36.6 | 79041099 | 746303 |
11 | Locked | 37.3 | 72946609 | 537730 |
12 | Locked | 37.3 | 55199589 | 164410 |
13 | Locked | 37.3 | 29431591 | 15348 |
14 | Locked | 37.6 | 21513330 | 7942 |
15 | Locked | 37.3 | 17516759 | 6953 |
16 | Locked | 37.6 | 17531589 | 7244 |
17 | Locked | 37.6 | 13634580 | 6970 |
18 | Locked | 37.3 | 7124394 | 6192 |
19 | Locked | 37.3 | 7266980 | 6745 |
20 | Locked | 37.3 | 8055023 | 5967 |
21 | Locked | 37.3 | 7969024 | 5860 |
22 | Locked | 38.6 | 7467484 | 6154 |
23 | Locked | 37.6 | 9135060 | 6141 |
24 | Locked | 38.6 | 6351937 | 5327 |
1 | 39400000 | 51 | 5120 | 32 qam | 6 |
2 | 25800000 | 49 | 5120 | 64 qam | 8 |
3 | 32600000 | 49.5 | 5120 | 32 qam | 7 |
4 | 46200000 | 51 | 5120 | 32 qam | 5 |
1 | ATDMA | 0 | 0 | 3 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 27-03-2021 19:43
on 28-03-2021 17:22
Hey @nuttyslack
Thanks for taking the time to update us on your connection issues.
I'm really sorry that the problems haven't been resolved yet, I have been looked into your account and can see that an SNR issue has been raised in your area with an estimated fix date and time of 6th April around 2pm under fault reference F008903471.
Steven_L
on 28-03-2021 17:59
Steven,
thanks for the reply and the fault reference, hopefully it will all be sorted then.
on 06-04-2021 19:58
any update on the fault, new logs and sam knows speed test below
on 06-04-2021 19:59
1 | 331000000 | 7.5 | 40 | 256 qam | 25 |
2 | 267000000 | 5.5 | 38 | 256 qam | 17 |
3 | 275000000 | 5.8 | 38 | 256 qam | 18 |
4 | 283000000 | 6.1 | 38 | 256 qam | 19 |
5 | 291000000 | 6.5 | 38 | 256 qam | 20 |
6 | 299000000 | 7 | 38 | 256 qam | 21 |
7 | 307000000 | 7 | 38 | 256 qam | 22 |
8 | 315000000 | 7.4 | 40 | 256 qam | 23 |
9 | 323000000 | 7.5 | 40 | 256 qam | 24 |
10 | 339000000 | 7.5 | 40 | 256 qam | 26 |
11 | 347000000 | 7.4 | 40 | 256 qam | 27 |
12 | 355000000 | 7.3 | 40 | 256 qam | 28 |
13 | 363000000 | 7.4 | 40 | 256 qam | 29 |
14 | 371000000 | 7.4 | 40 | 256 qam | 30 |
15 | 379000000 | 7.5 | 38 | 256 qam | 31 |
16 | 387000000 | 7.5 | 38 | 256 qam | 32 |
17 | 395000000 | 7.3 | 38 | 256 qam | 33 |
18 | 403000000 | 7.3 | 38 | 256 qam | 34 |
19 | 411000000 | 7.1 | 38 | 256 qam | 35 |
20 | 419000000 | 7.1 | 40 | 256 qam | 36 |
21 | 427000000 | 7.3 | 38 | 256 qam | 37 |
22 | 435000000 | 7.1 | 38 | 256 qam | 38 |
23 | 443000000 | 7.1 | 38 | 256 qam | 39 |
24 | 451000000 | 7.3 | 38 | 256 qam | 40 |
1 | Locked | 40.3 | 8 | 0 |
2 | Locked | 38.6 | 6 | 0 |
3 | Locked | 38.9 | 6 | 0 |
4 | Locked | 38.9 | 9 | 0 |
5 | Locked | 38.9 | 10 | 0 |
6 | Locked | 38.9 | 10 | 0 |
7 | Locked | 38.9 | 16 | 0 |
8 | Locked | 40.3 | 8 | 0 |
9 | Locked | 40.3 | 5 | 0 |
10 | Locked | 40.3 | 8 | 0 |
11 | Locked | 40.3 | 7 | 0 |
12 | Locked | 40.9 | 7 | 0 |
13 | Locked | 40.3 | 9 | 0 |
14 | Locked | 40.3 | 4 | 0 |
15 | Locked | 38.9 | 8 | 0 |
16 | Locked | 38.9 | 8 | 0 |
17 | Locked | 38.9 | 10 | 0 |
18 | Locked | 38.9 | 5 | 0 |
19 | Locked | 38.9 | 13 | 0 |
20 | Locked | 40.3 | 12 | 0 |
21 | Locked | 38.9 | 18 | 0 |
22 | Locked | 38.9 | 15 | 0 |
23 | Locked | 38.9 | 24 | 0 |
24 | Locked | 38.9 | 2 | 0 |
1 | 39400000 | 44.5 | 5120 | 64 qam | 6 |
2 | 25800000 | 44.5 | 5120 | 64 qam | 8 |
3 | 32600002 | 44.5 | 5120 | 64 qam | 7 |
4 | 46200000 | 44.5 | 5120 | 64 qam | 5 |
on 06-04-2021 19:59
06/04/2021 14:50:17 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2021 10:00:41 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:31 | critical | TFTP Request Retries exceeded, CM unable to register |
01/01/1970 00:00:31 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:21 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:24 | Warning! | ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:24 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:38 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:34 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:11 | Warning! | ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:10 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:9 | Warning! | ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:5 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:4 | Warning! | ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:3 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:2 | Warning! | ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:00:0 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2021 09:42:36 | Warning! | ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 06-04-2021 20:01
