on 12-03-2021 21:47
Yet again very slow speeds at night, bqm from last night below along with router logs
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a45434949700d3637a0940c274c6825af646e1c3-12-03-2021
1 | 331000000 | 4.5 | 38 | 256 qam | 25 |
2 | 203000000 | 0.5 | 36 | 256 qam | 9 |
3 | 211000000 | 0.5 | 36 | 256 qam | 10 |
4 | 219000000 | 0.5 | 36 | 256 qam | 11 |
5 | 227000000 | 0.2 | 36 | 256 qam | 12 |
6 | 235000000 | 0.4 | 36 | 256 qam | 13 |
7 | 243000000 | 0.7 | 37 | 256 qam | 14 |
8 | 251000000 | 1.4 | 37 | 256 qam | 15 |
9 | 259000000 | 1.5 | 37 | 256 qam | 16 |
10 | 267000000 | 2 | 36 | 256 qam | 17 |
11 | 275000000 | 2.2 | 37 | 256 qam | 18 |
12 | 283000000 | 2.7 | 37 | 256 qam | 19 |
13 | 291000000 | 3 | 37 | 256 qam | 20 |
14 | 299000000 | 3.7 | 37 | 256 qam | 21 |
15 | 307000000 | 3.7 | 37 | 256 qam | 22 |
16 | 315000000 | 4 | 38 | 256 qam | 23 |
17 | 323000000 | 4.4 | 38 | 256 qam | 24 |
18 | 371000000 | 4.4 | 37 | 256 qam | 26 |
19 | 379000000 | 4.3 | 37 | 256 qam | 27 |
20 | 387000000 | 4.4 | 37 | 256 qam | 28 |
21 | 395000000 | 4.4 | 38 | 256 qam | 29 |
22 | 403000000 | 4.5 | 38 | 256 qam | 30 |
23 | 411000000 | 4.5 | 38 | 256 qam | 31 |
24 | 419000000 | 4.6 | 38 | 256 qam | 32 |
1 | Locked | 38.6 | 65 | 232 |
2 | Locked | 36.6 | 96 | 265 |
3 | Locked | 36.6 | 128 | 223 |
4 | Locked | 36.6 | 157 | 274 |
5 | Locked | 36.6 | 227 | 217 |
6 | Locked | 36.6 | 142 | 235 |
7 | Locked | 37.3 | 132 | 268 |
8 | Locked | 37.3 | 115 | 262 |
9 | Locked | 37.3 | 110 | 307 |
10 | Locked | 36.6 | 170 | 270 |
11 | Locked | 37 | 195 | 229 |
12 | Locked | 37.6 | 167 | 241 |
13 | Locked | 37.6 | 107 | 247 |
14 | Locked | 37.3 | 119 | 252 |
15 | Locked | 37.3 | 82 | 280 |
16 | Locked | 38.6 | 91 | 210 |
17 | Locked | 38.6 | 98 | 208 |
18 | Locked | 37.6 | 64 | 361 |
19 | Locked | 37.6 | 86 | 222 |
20 | Locked | 37.6 | 100 | 233 |
21 | Locked | 38.6 | 73 | 266 |
22 | Locked | 38.6 | 89 | 196 |
23 | Locked | 38.6 | 98 | 196 |
24 | Locked | 38.6 | 106 | 184 |
1 | 39400187 | 44.3 | 5120 | 64 qam | 6 |
2 | 25800000 | 44.3 | 5120 | 64 qam | 8 |
3 | 32600068 | 45.8 | 5120 | 64 qam | 7 |
4 | 46199998 | 45.8 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 20-03-2021 19:06
VM engineer came this afternoon, speed was alright he changed the white internal box and some connectors from the cable ends, all was ok until 6.30pm when the speed (dropped wired and wifi), latency and ping went high, theres definitely a network problem, the connection during the day isnt as stable as it used to be its up and down more than a yo yo, new logs and BQM below
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a6f9633d685ab8c01a33d2fd572f682ef1ec8f93
1 | 331000000 | 7.6 | 38 | 256 qam | 25 |
2 | 203000000 | 4.9 | 38 | 256 qam | 9 |
3 | 211000000 | 4.8 | 38 | 256 qam | 10 |
4 | 219000000 | 4.6 | 38 | 256 qam | 11 |
5 | 227000000 | 4.6 | 38 | 256 qam | 12 |
6 | 235000000 | 4.5 | 38 | 256 qam | 13 |
7 | 243000000 | 4.4 | 38 | 256 qam | 14 |
8 | 251000000 | 4.5 | 38 | 256 qam | 15 |
9 | 259000000 | 4.8 | 38 | 256 qam | 16 |
10 | 267000000 | 5.4 | 38 | 256 qam | 17 |
11 | 275000000 | 5.9 | 38 | 256 qam | 18 |
12 | 283000000 | 6.4 | 38 | 256 qam | 19 |
13 | 291000000 | 6.6 | 38 | 256 qam | 20 |
14 | 299000000 | 7.1 | 38 | 256 qam | 21 |
15 | 307000000 | 7.3 | 38 | 256 qam | 22 |
16 | 315000000 | 7.5 | 38 | 256 qam | 23 |
17 | 323000000 | 7.6 | 38 | 256 qam | 24 |
18 | 371000000 | 7 | 38 | 256 qam | 26 |
19 | 379000000 | 7 | 38 | 256 qam | 27 |
20 | 387000000 | 7 | 38 | 256 qam | 28 |
21 | 395000000 | 6.8 | 38 | 256 qam | 29 |
22 | 403000000 | 6.9 | 38 | 256 qam | 30 |
23 | 411000000 | 6.8 | 38 | 256 qam | 31 |
24 | 419000000 | 7 | 38 | 256 qam | 32 |
1 | Locked | 38.9 | 13183 | 23206 |
2 | Locked | 38.6 | 397256 | 41028 |
3 | Locked | 38.6 | 503532 | 29838 |
4 | Locked | 38.6 | 557518 | 19048 |
5 | Locked | 38.6 | 465500 | 24709 |
6 | Locked | 38.9 | 324205 | 23829 |
7 | Locked | 38.6 | 281938 | 23269 |
8 | Locked | 38.9 | 261875 | 25254 |
9 | Locked | 38.6 | 333586 | 22479 |
10 | Locked | 38.6 | 349827 | 22066 |
11 | Locked | 38.6 | 258683 | 28361 |
12 | Locked | 38.9 | 144617 | 22689 |
13 | Locked | 38.9 | 62142 | 28721 |
14 | Locked | 38.6 | 41506 | 19411 |
15 | Locked | 38.6 | 34653 | 18565 |
16 | Locked | 38.9 | 31938 | 17422 |
17 | Locked | 38.9 | 22865 | 17209 |
18 | Locked | 38.6 | 15665 | 11379 |
19 | Locked | 38.6 | 17245 | 12937 |
20 | Locked | 38.9 | 16360 | 15977 |
21 | Locked | 38.9 | 16610 | 16997 |
22 | Locked | 38.9 | 16184 | 16598 |
23 | Locked | 38.9 | 17506 | 15907 |
24 | Locked | 38.9 | 9932 | 39259 |
1 | 39400000 | 48 | 5120 | 64 qam | 6 |
2 | 25800000 | 47.5 | 5120 | 32 qam | 8 |
3 | 32600000 | 47.5 | 5120 | 64 qam | 7 |
4 | 46200000 | 48 | 5120 | 64 qam | 5 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 20-03-2021 19:06
20/03/2021 18:42:26 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:42:26 | critical | SYNC Timing Synchronization failure - Loss of Sync;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:40:42 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:40:42 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:37:31 | Warning! | RCS Partial Service;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:37:31 | critical | SYNC Timing Synchronization failure - Loss of Sync;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:31:16 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:31:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:30:20 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:30:20 | critical | SYNC Timing Synchronization failure - Loss of Sync;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:28:18 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:28:18 | critical | SYNC Timing Synchronization failure - Loss of Sync;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 18:27:45 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 13:59:32 | notice | LAN login Success;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 13:42:30 | critical | No Ranging Response received - T3 time-out;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 13:42:1 | Warning! | Lost MDD Timeout;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 13:41:56 | critical | SYNC Timing Synchronization failure - Loss of Sync;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 13:41:56 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0; |
20/03/2021 13:35:0 | Warning! | RCS Partial Service;;CM-QOS=1.1;CM-VER=3.0 |
on 22-03-2021 13:50
That doesn't look right at all - just to confirm it's been the same way since the engineer left?
Cheers.
on 22-03-2021 15:28
It's still the same with the speeds from 6.30pm onwards, very unstable and Saturday it went altogether but came back after a reboot. Maybe it's over utilisation on the network, maybe when everything is some kind of normal it will settle.
I tried showing the engineer the bqm but he wasn't interested.
on 22-03-2021 17:56
Unsure why they wasn't interested as it would only help them - apologies for that.
From 6:30PM when does it last until? Can you let me know how it goes tonight and can you screen shot the time periods please.
Cheers.
on 23-03-2021 12:25
thanks for the reply, didnt get chance to test it last night, will try tonight, it can last until at least midnight come the morning its back to full speed, until roughly the same time again, normally its around 8-830pm it starts.
on 23-03-2021 13:08
on 23-03-2021 18:21
Did a speedtest on your webpage, less than a 3rd of the speed it should be.
on 23-03-2021 19:31
about 1hr 15 mins later slightly worse speed
on 23-03-2021 19:46
1 | 331000000 | 7.5 | 38 | 256 qam | 25 |
2 | 203000000 | 4.8 | 38 | 256 qam | 9 |
3 | 211000000 | 4.6 | 38 | 256 qam | 10 |
4 | 219000000 | 4.5 | 38 | 256 qam | 11 |
5 | 227000000 | 4.1 | 38 | 256 qam | 12 |
6 | 235000000 | 4.1 | 38 | 256 qam | 13 |
8 | 251000000 | 4.8 | 38 | 256 qam | 15 |
9 | 259000000 | 5 | 38 | 256 qam | 16 |
10 | 267000000 | 5.5 | 38 | 256 qam | 17 |
11 | 275000000 | 5.8 | 38 | 256 qam | 18 |
13 | 291000000 | 6.5 | 38 | 256 qam | 20 |
14 | 299000000 | 7 | 38 | 256 qam | 21 |
15 | 307000000 | 7.1 | 38 | 256 qam | 22 |
16 | 315000000 | 7.4 | 38 | 256 qam | 23 |
17 | 323000000 | 7.5 | 38 | 256 qam | 24 |
18 | 371000000 | 6.6 | 38 | 256 qam | 26 |
19 | 379000000 | 6.5 | 38 | 256 qam | 27 |
20 | 387000000 | 6.5 | 38 | 256 qam | 28 |
21 | 395000000 | 6.5 | 38 | 256 qam | 29 |
22 | 403000000 | 6.5 | 38 | 256 qam | 30 |
23 | 411000000 | 6.5 | 38 | 256 qam | 31 |
24 | 419000000 | 6.6 | 38 | 256 qam | 32 |
1 | Locked | 38.9 | 2 | 0 |
2 | Locked | 38.6 | 22 | 0 |
3 | Locked | 38.6 | 27 | 0 |
4 | Locked | 38.6 | 89 | 0 |
5 | Locked | 38.6 | 55 | 11 |
6 | Locked | 38.9 | 54 | 0 |
7 | Locked | 38.9 | 48 | 3 |
8 | Locked | 38.9 | 8 | 0 |
9 | Locked | 38.6 | 16 | 0 |
10 | Locked | 38.9 | 16 | 0 |
11 | Locked | 38.6 | 33 | 0 |
12 | Locked | 38.6 | 46 | 0 |
13 | Locked | 38.9 | 23 | 0 |
14 | Locked | 38.6 | 54 | 0 |
15 | Locked | 38.6 | 35 | 0 |
16 | Locked | 38.6 | 24 | 0 |
17 | Locked | 38.6 | 36 | 0 |
18 | Locked | 38.9 | 0 | 0 |
19 | Locked | 38.9 | 4 | 0 |
20 | Locked | 38.9 | 9 | 0 |
21 | Locked | 38.9 | 6 | 0 |
22 | Locked | 38.6 | 11 | 0 |
23 | Locked | 38.9 | 6 | 0 |
24 | Locked | 38.9 | 15 | 0 |
