on 07-09-2021 20:45
I am looking for help as I am beyond my end with the packet loss of my connection.
Long Story short, had 500Mb, on the 12th August I upgraded to Gig1, Things ran Ok for a bit then over the last 2 weeks the packet loss has been unbearable to the below:
This as you can see is unusable. 3 Engineers have come round over the last 48 hours claiming that things will be fixed, No they haven't. The last network engineer went to the cabinet to adjust the slope as it was way out apparently. It didnt work, I have subsequently downgraded back to 500mb and it's still terrible and unsable. This is currently on the Hub4
How do I fix this? I have had cable pulls, severed cables, recables, splitters, attenuators all sorts over the last 6months. Stats below, advise appreciated.
3.0 Downstream channels
25 | 331000000 | 8.199997 | 38.983261 | QAM256 | 25 |
10 | 211000000 | 7.599998 | 38.605377 | QAM256 | 10 |
11 | 219000000 | 7.900002 | 38.605377 | QAM256 | 11 |
12 | 227000000 | 8.000000 | 38.605377 | QAM256 | 12 |
13 | 235000000 | 7.599998 | 38.605377 | QAM256 | 13 |
14 | 243000000 | 7.400002 | 38.983261 | QAM256 | 14 |
15 | 251000000 | 7.300003 | 38.983261 | QAM256 | 15 |
16 | 259000000 | 8.000000 | 38.983261 | QAM256 | 16 |
17 | 267000000 | 8.500000 | 38.605377 | QAM256 | 17 |
18 | 275000000 | 8.900002 | 38.983261 | QAM256 | 18 |
19 | 283000000 | 8.099998 | 38.605377 | QAM256 | 19 |
20 | 291000000 | 7.599998 | 38.605377 | QAM256 | 20 |
21 | 299000000 | 7.400002 | 38.983261 | QAM256 | 21 |
22 | 307000000 | 8.300003 | 38.983261 | QAM256 | 22 |
23 | 315000000 | 9.000000 | 38.983261 | QAM256 | 23 |
24 | 323000000 | 9.099998 | 38.983261 | QAM256 | 24 |
26 | 339000000 | 7.800003 | 38.605377 | QAM256 | 26 |
27 | 347000000 | 7.900002 | 38.983261 | QAM256 | 27 |
28 | 355000000 | 8.300003 | 38.605377 | QAM256 | 28 |
29 | 363000000 | 8.900002 | 38.983261 | QAM256 | 29 |
30 | 371000000 | 9.500000 | 40.366287 | QAM256 | 30 |
31 | 379000000 | 9.300003 | 38.983261 | QAM256 | 31 |
32 | 387000000 | 9.000000 | 40.366287 | QAM256 | 32 |
33 | 395000000 | 9.000000 | 38.983261 | QAM256 | 33 |
34 | 403000000 | 9.300003 | 38.983261 | QAM256 | 34 |
35 | 411000000 | 10.000000 | 38.983261 | QAM256 | 35 |
36 | 419000000 | 10.900002 | 40.366287 | QAM256 | 36 |
37 | 427000000 | 11.000000 | 38.983261 | QAM256 | 37 |
38 | 435000000 | 11.099998 | 38.983261 | QAM256 | 38 |
39 | 443000000 | 11.000000 | 38.983261 | QAM256 | 39 |
40 | 451000000 | 11.000000 | 40.366287 | QAM256 | 40 |
25 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.605377 | 1 | 0 |
11 | Locked | 38.605377 | 1 | 0 |
12 | Locked | 38.605377 | 1 | 0 |
13 | Locked | 38.605377 | 0 | 0 |
14 | Locked | 38.983261 | 1 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.605377 | 1 | 0 |
18 | Locked | 38.983261 | 1 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.605377 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.605377 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 40.366287 | 0 | 0 |
33 | Locked | 38.983261 | 0 | 0 |
34 | Locked | 38.983261 | 0 | 0 |
35 | Locked | 38.983261 | 0 | 0 |
36 | Locked | 40.366287 | 0 | 0 |
37 | Locked | 38.983261 | 0 | 0 |
38 | Locked | 38.983261 | 0 | 0 |
39 | Locked | 38.983261 | 0 | 0 |
40 | Locked | 40.366287 | 0 | 0 |
on 07-09-2021 21:15
3.1 Downstream channels
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 38 | 4.2 | 4667366 | 0 |
3.0 Upstream channels
1 | 32600000 | 40.270599 | 5120 KSym/sec | 64QAM | 5 |
2 | 39400000 | 40.770599 | 5120 KSym/sec | 64QAM | 4 |
3 | 46200000 | 40.770599 | 5120 KSym/sec | 64QAM | 3 |
4 | 53700000 | 41.770599 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
Tue Sep 7 18:08:07 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 7 18:08:14 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Sep 7 18:13:51 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 08-09-2021 07:00
Downstream power levels appear to be too high on some channels, but given three recent visits and the extent of work already carried out, this is looking like one of those problems that is beyond VM's capability to isolate and resolve. It shouldn't be - it's an RF noise issue somewhere between the back of your hub and the relatively short distance to the street cabinet (including the kit inside), it should be a straightforward job for a technician with the right skills and equipment, but as you've found, sometimes the company struggle.
Note for forum staff: Can this be escalated to the AFM? No VM connection should show a BQM as skanky as this, and after all the effort already described it looks like it needs a fresh approach.
If this has been going on for six months then you may want to complain and seek compensation for the poor service and ineffective support, but treat that as a separate battle to getting this fixed - you'd probably need to formally complain, be fobbed off and then escalate to CISAS.
on 08-09-2021 08:21
Hi Comradebo,
Thank you for your post.
I was really sorry to hear of the experience and ongoing issues you've had with your broadband, which is obviously quite evident in your BQM graph. I can certainly imagine how frustrated/exhausted you must be at this point and want to do everything I can to help.
@Andrew-G - I completely agree. I'm going to make contact with the Area Field Manage now and ask what they think the best next step would be. They will most likely arrange for a Senior Engineer to attend.
As soon as I have an update on this for you I will let you know from here. If you need anything else in the meantime @Comradebo just give me a shout.
Kind regards
Beth
on 08-09-2021 09:15
Thank you both for the response. I would like 1Gb internet but I thought that the 500Mb downgrade would help. A reboot on the router this morning has made things worse.
on 08-09-2021 09:24
Hi Comradebo,
The Area Field Manager has responded and is looking into this case as a priority for you.
He has arranged for a Senior Technician to attend the property tomorrow between 1pm-6pm. I hope that's okay.
A full health check is going to be completed and reported back to him after the visit.
Please do let us know how the visit goes 🙂
Kind regards
Beth
on 08-09-2021 09:42
Thank you Beth_G
The engineer will not have access to the property tomorrow. Given that I have had all these problems and unable to work, can they come today?
on 08-09-2021 17:19
Just as an update, my next door neighbour has the same issue with 50-60% packet loss.
It has to be a cabinet/network issue here.
on 08-09-2021 19:54
@Comradebo wrote:Just as an update, my next door neighbour has the same issue with 50-60% packet loss.
…. Snip
And if your neighbour’s BQM looks anything like yours, then I’d bet good money on it being a failing amp in a cabinet.
on 08-09-2021 20:01
It does. I’ll be posting the stats up tomorrow
