500Mb to Gig1 - Slower speeds than before - Solved
Wizen1
Just joined
EDIT:
Hi again,
I left the Hub4 turned off for half an hour, and then tried again, and it appears to be slowly shifting up towards the expected 900Mb. Feel free to delete the post below, mods.
____________________________________________________________________________________________________________________
Hi all,
I've just upgraded to gig1 from 500Mb. I'm running a completely wired cat5e network, with no other devices turned on, straight through to a gigabit port on my router, and the download speed I'm getting is significantly worse than before the upgrade earlier today. I'm still using the hub4, and my hub5 is due to arrive in 2 weeks. Any ideas?
3.0 Downstream channels
233150000004.640.4QAM25623
1139000000639QAM2561
2147000000639QAM2562
31550000005.940.4QAM2563
4163000000640.4QAM2564
5171000000640.9QAM2565
6179000000640.4QAM2566
71870000006.239QAM2567
81950000006.240.4QAM2568
92030000006.240.4QAM2569
102110000006.240.4QAM25610
112190000006.140.4QAM25611
12227000000640.4QAM25612
132350000005.840.4QAM25613
142430000005.840.4QAM25614
152510000005.640.4QAM25615
162590000005.440.4QAM25616
17267000000540.4QAM25617
182750000005.340.4QAM25618
192830000005.540.4QAM25619
202910000005.440.9QAM25620
212990000005.140.4QAM25621
223070000004.640.4QAM25622
243230000004.340.4QAM25624
253310000004.339QAM25625
263390000004.339QAM25626
273470000004.539QAM25627
283550000004.740.4QAM25628
293630000004.640.4QAM25629
303710000004.940.4QAM25630
313790000004.340.4QAM25631
23Locked40.36628740
1Locked38.98326150
2Locked38.98326160
3Locked40.36628744990
4Locked40.36628700
5Locked40.94620950
6Locked40.36628700
7Locked38.98326140
8Locked40.366287980
9Locked40.36628780
10Locked40.36628700
11Locked40.36628700
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked40.36628700
16Locked40.36628770
17Locked40.36628700
18Locked40.36628700
19Locked40.36628700
20Locked40.94620900
21Locked40.36628700
22Locked40.36628700
24Locked40.36628700
25Locked38.98326100
26Locked38.98326100
27Locked38.98326100
28Locked40.36628700
29Locked40.36628700
30Locked40.36628700
31Locked40.36628700
3.1 Downstream channels
159964K1880QAM4096424
159Locked436.334868600
1 REPLY 1
Matthew_ML
Hey Wizen1, thank you for reaching out and a warm welcome to the community, I am sorry to see you were having some connection issues.
However I am glad they are now resolved, please do feel free to reach back out if you ever need anything. Thanks
Matt - Forum Team
New around here?
