on 12-12-2022 18:55
For the past 18 months my internet has been very flaky most days a speed test will show 10 mbps download speed, with a 35+mbps up.
I have had nine (yes really 9) engineer visits, with another planned for Wednesday.
I have been told its my ethernet cable yet I have tried at least 4 different cables. Then they said I had too many devices connected so reset everything and tried with just one PC connected via RJ45 cable. Then I was told its the 30 plus year old cables in my home so ended up with a rewire and still nothing changed, next it was blame the router (actually on my 3rd now), next they claimed the wiring to my home from the pit needed changing - had to wait 2 weeks and still that hasnt fixed it. The only thing I am sure about is that when it rains the speed is even slower than a dry day.
I have copied everything from the router status page hoping someone can see something the engineers keep missing. Kelly communications did say that the cables to the pit are over 30 years old and brittle and they have cracks in the insulation - not sure why my up speed is as advertised if this is the case.
Can't log into the router, as the info on the sticker on the base fails.
Thanks in advance.
SFID | 27735 |
Max Traffic Rate | 38500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 1 | 0 |
1 | 331000000 | 6 | 40 | 256 qam | 25 |
2 | 203000000 | 5 | 38 | 256 qam | 9 |
3 | 211000000 | 5 | 38 | 256 qam | 10 |
4 | 219000000 | 4.9 | 38 | 256 qam | 11 |
5 | 227000000 | 5 | 38 | 256 qam | 12 |
6 | 235000000 | 5 | 38 | 256 qam | 13 |
7 | 243000000 | 4.5 | 38 | 256 qam | 14 |
8 | 251000000 | 4.5 | 38 | 256 qam | 15 |
9 | 259000000 | 4.6 | 38 | 256 qam | 16 |
10 | 267000000 | 4.5 | 40 | 256 qam | 17 |
11 | 275000000 | 4.8 | 40 | 256 qam | 18 |
12 | 283000000 | 4.5 | 38 | 256 qam | 19 |
13 | 291000000 | 5 | 40 | 256 qam | 20 |
14 | 299000000 | 5.4 | 38 | 256 qam | 21 |
15 | 307000000 | 5.3 | 38 | 256 qam | 22 |
16 | 315000000 | 5.8 | 40 | 256 qam | 23 |
17 | 323000000 | 5.9 | 38 | 256 qam | 24 |
18 | 339000000 | 6.4 | 40 | 256 qam | 26 |
19 | 347000000 | 6 | 40 | 256 qam | 27 |
20 | 355000000 | 6.3 | 40 | 256 qam | 28 |
21 | 363000000 | 6.5 | 40 | 256 qam | 29 |
22 | 371000000 | 6.6 | 40 | 256 qam | 30 |
23 | 379000000 | 6.6 | 40 | 256 qam | 31 |
24 | 387000000 | 6.1 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 27 | 0 |
2 | Locked | 38.9 | 39 | 0 |
3 | Locked | 38.9 | 37 | 0 |
4 | Locked | 38.9 | 28 | 0 |
5 | Locked | 38.6 | 24 | 0 |
6 | Locked | 38.9 | 34 | 0 |
7 | Locked | 38.9 | 48 | 0 |
8 | Locked | 38.9 | 43 | 0 |
9 | Locked | 38.6 | 43 | 0 |
10 | Locked | 40.9 | 50 | 0 |
11 | Locked | 40.3 | 37 | 0 |
12 | Locked | 38.6 | 57 | 0 |
13 | Locked | 40.3 | 43 | 0 |
14 | Locked | 38.9 | 32 | 7 |
15 | Locked | 38.9 | 29 | 0 |
16 | Locked | 40.3 | 29 | 0 |
17 | Locked | 38.6 | 19 | 0 |
18 | Locked | 40.3 | 46 | 0 |
19 | Locked | 40.3 | 48 | 0 |
20 | Locked | 40.3 | 41 | 0 |
21 | Locked | 40.3 | 29 | 0 |
22 | Locked | 40.9 | 45 | 0 |
23 | Locked | 40.9 | 20 | 0 |
24 | Locked | 40.3 | 65 | 0 |
Acquired Downstream Channel (Hz) | 331000000 | Locked |
Ranged Upstream Channel (Hz) | 36600000 | Locked |
Provisioning State | Online |
Answered! Go to Answer
on 12-12-2022 20:59
on 12-12-2022 18:57
12/12/2022 18:22:8 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/12/2022 06:22:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/12/2022 21:31:47 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/12/2022 21:31:47 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/12/2022 22:52:59 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/12/2022 21:47:43 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/12/2022 14:31:34 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/12/2022 14:30:37 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/12/2022 14:30:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/12/2022 14:30:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/12/2022 15:07:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/12/2022 04:12:7 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/12/2022 04:12:7 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2022 06:02:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2022 04:33:27 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2022 04:33:27 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/12/2022 02:02:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2022 18:00:4 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2022 17:58:19 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2022 17:58:15 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 12-12-2022 19:00
Even though in the past I have had the option to end my contract without penalties due to the constant slow speeds, when I tried SKY using a BT line I only got 6mbps as it seems the 50 year old BT cables are worse than what Virgin have here.
on 12-12-2022 19:52
on 12-12-2022 20:03
1 | 36600000 | 41.3 | 5120 | 64 qam | 3 |
2 | 23600000 | 40.8 | 5120 | 64 qam | 5 |
3 | 30100000 | 40.8 | 5120 | 64 qam | 4 |
4 | 43099993 | 41.3 | 5120 | 64 qam | 2 |
5 | 49600000 | 41.3 | 5120 | 64 qam | 1 |
on 12-12-2022 20:59
on 12-12-2022 21:30
on 12-12-2022 21:35
on 12-12-2022 21:38
on 12-12-2022 22:37
