  • 6
fournicols
Message 1 of 11
2 TVs same house 1 buffers 1 doesn’t. Why??
TV in the bedroom connects to router with Wi-fi it has a fire stick and  has no buffering with streaming. The TV in the living room which also has fire stick and is connected to router with Ethernet cable buffers every 3 seconds when streaming football making it unwatchable. Any suggestions please?
  • 9.46K
  • 980
  • 1.49K
Message 2 of 11
Re: 2 TVs same house 1 buffers 1 doesn’t. Why??
Try a new Cat6a cable. Try a different port on the Hub? What does it do if you connect it by wifi rather than ethernet ?
  • 6
fournicols
Message 3 of 11
Hi it was the same using WiFi so we changed to Ethernet. The cable you mention where does that connect from and to?
  • 4.72K
  • 319
  • 792
Roger_Gooner
Superstar
Message 4 of 11
Where is the router? The WiFi in the living room is probably worse than in the bedroom.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 6
fournicols
Message 5 of 11
The router is right next to the TV
  • 6
fournicols
Message 6 of 11
Sorry the living room TV where the buffering happens
  • 165
  • 5
  • 13
Moderator
Moderator
Message 7 of 11
Hi fournicols,
Sorry to hear you are experiencing buffering issues.
Even though your TV is connected through Ethernet, the Fire stick connects through WiFi, so being connected through Ethernet connection to your router does not actually have an influence to the Fire stick.
Let's first try to check if the position of your Hub is impacting the WiFi connection. Please try the steps in this link to see how you can adjust the Hub position.
If this doesn't work, I would recommend to contact the manufacturer support of Amazon, as the issue might be caused by the Fire stick itself.
Please let me know how it goes.
^Jona
  • 4.06K
  • 481
  • 1.31K
Message 8 of 11
Unless @fournicols is using an Ethernet adapter like this one:
https://www.amazon.co.uk/Amazon-Ethernet-Adaptor-Remote-models/dp/B01LXP5TXI
______________________
Scott
My setup: Vivid 200 Optical fibre with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Click to learn more about VIP
Use Kudos to say thanks
  • 6
fournicols
Message 9 of 11
Hi I am using that type, The Ethernet is connected to the fire stick. Buffering happens when streaming sport using WiFi or Ethernet, but the WiFi fire stick connection on the bedroom TV is stable, no buffering ??
  • 2.82K
  • 142
  • 419
jpeg1
Trouble shooter
Message 10 of 11
Can you replace the ethernet cable to the Firestick?
Have you tried swapping the two Firesticks?
