on 27-02-2023 00:35
Been watching this now since the last software update on Wed 15/02/2023 my upload is perfectly fine but my download is getting worse by the day.
Stats look fine, but internet is crawling downloads are so slow
3.0 Downstream channels
1 139000000 3.9 40.4 QAM256 1
2 147000000 4 40.9 QAM256 2
3 155000000 3.9 40.9 QAM256 3
4 163000000 3.5 40.9 QAM256 4
5 171000000 3.4 40.4 QAM256 5
6 179000000 3.3 40.4 QAM256 6
7 187000000 3.3 40.4 QAM256 7
8 195000000 3 40.9 QAM256 8
9 203000000 2.8 40.9 QAM256 9
10 211000000 2.7 40.4 QAM256 10
11 219000000 2.5 40.4 QAM256 11
12 227000000 2.3 40.4 QAM256 12
13 235000000 2 40.4 QAM256 13
14 243000000 1.7 40.4 QAM256 14
15 251000000 1.5 40.4 QAM256 15
16 259000000 1.8 40.9 QAM256 16
17 267000000 2.2 40.9 QAM256 17
18 275000000 2.3 40.4 QAM256 18
19 283000000 2.2 40.9 QAM256 19
20 291000000 2.1 40.4 QAM256 20
21 299000000 2 40.4 QAM256 21
22 307000000 2.2 40.4 QAM256 22
23 315000000 2 40.4 QAM256 23
24 323000000 1.9 40.9 QAM256 24
25 331000000 1.7 40.4 QAM256 25
26 339000000 1.7 40.4 QAM256 26
27 347000000 1.9 40.9 QAM256 27
28 355000000 2.1 40.4 QAM256 28
29 363000000 1.8 40.9 QAM256 29
30 371000000 1.3 40.4 QAM256 30
31 379000000 0.5 40.9 QAM256 31
1 Locked 40.366287 0 0
2 Locked 40.946209 0 0
3 Locked 40.946209 0 0
4 Locked 40.946209 0 0
5 Locked 40.366287 0 0
6 Locked 40.366287 0 0
7 Locked 40.366287 0 0
8 Locked 40.946209 0 0
9 Locked 40.946209 0 0
10 Locked 40.366287 0 0
11 Locked 40.366287 0 0
12 Locked 40.366287 0 0
13 Locked 40.366287 0 0
14 Locked 40.366287 0 0
15 Locked 40.366287 0 0
16 Locked 40.946209 0 0
17 Locked 40.946209 0 0
18 Locked 40.366287 0 0
19 Locked 40.946209 0 0
20 Locked 40.366287 0 0
21 Locked 40.366287 0 0
22 Locked 40.366287 0 0
23 Locked 40.366287 0 0
24 Locked 40.946209 0 0
25 Locked 40.366287 0 0
26 Locked 40.366287 0 0
27 Locked 40.946209 0 0
28 Locked 40.366287 0 0
29 Locked 40.946209 0 0
30 Locked 40.366287 0 0
31 Locked 40.946209 0 0
3.1 Downstream channels
159 96 4K 1840 QAM4096 759
159 Locked 43 -0.9 6840368 0
3.0 Upstream channels
1 43100000 50 5120 KSym/sec QAM64 2
2 23600000 48.5 5120 KSym/sec QAM64 5
3 30100000 49 5120 KSym/sec QAM64 4
4 36600000 49.5 5120 KSym/sec QAM64 3
5 49600000 50.5 5120 KSym/sec QAM64 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
5 ATDMA 0 0 0 0
3.1 Upstream channels
6 10.0 45.0 2K QAM128
6 OFDMA 200 53.9 0 0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
54k;fg87dsfd;kfoA,.iyewrk
SFID
540
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
539
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Sun 26/02/2023
23:24:36 6 US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 26/02/2023
23:24:19 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 26/02/2023
02:17:21 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 26/02/2023
02:17:04 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 25/02/2023
14:38:01 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 25/02/2023
14:38:01 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
06:45:07 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
02:39:57 6 US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
02:39:38 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
02:39:32 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
02:38:18 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
02:38:17 5 B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
02:37:08 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
02:36:48 4 Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
00:21:39 3 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
00:20:29 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/02/2023
00:20:24 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 21/02/2023
23:16:04 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 21/02/2023
02:36:38 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 21/02/2023
02:36:38 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 18/02/2023
16:55:37 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 17/02/2023
17:40:14 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 17/02/2023
17:40:14 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 17/02/2023
00:42:50 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 16/02/2023
02:51:12 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 16/02/2023
02:51:12 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 16/02/2023
02:50:54 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 15/02/2023
01:17:05 6 US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 15/02/2023
01:16:48 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 15/02/2023
01:14:03 6 SW download Successful - Via NMS
Wed 15/02/2023
01:03:26 6 SW Download INIT - Via NMS
Mon 13/02/2023
22:33:34 6 US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/02/2023
22:33:34 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/02/2023
22:33:18 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/02/2023
03:29:27 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/02/2023
21:26:49 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/02/2023
21:26:48 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 10/02/2023
03:09:59 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 09/02/2023
23:24:19 6 US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 09/02/2023
23:24:19 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 09/02/2023
23:24:04 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 09/02/2023
13:43:29 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 08/02/2023
19:29:38 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 08/02/2023
19:29:38 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/02/2023
09:30:34 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/02/2023
08:42:11 6 DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 05/02/2023
08:42:10 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 03/02/2023
03:37:18 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/02/2023
00:07:43 6 US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 02/02/2023
00:07:30 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
on 06-03-2023 15:26
on 06-03-2023 16:05
No legacy my nic is working completely fine, plus it's happening on all other devices.
on 06-03-2023 16:50
Thats not showing the link speed and should be set to auto
do you have a hub 4 or 5?
on 06-03-2023 17:36
Sorry I was going to upload the picture earlier showing the link speed but had to go out.
The link speed is showing 1Gb (will upload PIC later) it's hub4
on 06-03-2023 17:56
@lojelo5 wrote:The link speed is showing 1Gb (will upload PIC later) it's hub4
So you should not be setting the NIC to 2.5Gb
When your speed drops check link speed
on 06-03-2023 21:07
The nic is automatically set at 2.5Gb because it's a 2.5Gb nic this has never changed in all the years I have had it. My download speed problem only started the day after the last software update to the hub4.
There is no point in checking the line speed because like I have said previously this is happening on several PC's not just 1 PC this is a VM issue not on my end. The hub4 was rebooted many times and everytime I rebooted it download speed went back to normal no idea for how long because it varies then speed will be all over the place once again until I reboot the hub.
So no point in checking the line speed everytime it goes down.
It's been ok for most of today every speed test that I have done as been over 940Mbps.
on 06-03-2023 21:30
NICs should always be left to auto negotiate the link speed, if they can't negotiate the fastest speeds that both sides support then there is a fault, and forcing a speed is at best going to paper over the problem and at worst it will prevent the link from functioning.
on 07-03-2023 08:21
What do we expect? It's virgin media! They are full of rubbish service! Virgin always lying to you!
I enjoyed my 5G Home Broadband download speed 675/80 better than virgin media
on 07-03-2023 15:31
Just to say I am having worse speeds since upgrading to 1Gb than I ever had with my M500 (which was very good).
I might have to get the engineer out I think.
on 09-03-2023 18:54
Hi @umpa
Thanks for posting on our community forum and sorry to hear about your broadband speed issue
I've had a remote check and all the power and signal levels look fine right now, how has your connection been over the past couple of days?
