on 27-10-2021 14:05
I've just upgraded my account to the 1Gig broadband only service and I'm dissapointed to see that the download rates or only marginally better than the 500MB I was on. i.e returning from 450 to 550 on speedtests.
The upload as increased to the advertised 52Mbps.
Here's my logs if the help:
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.946209 | 0 | 0 |
21 | Locked | 40.946209 | 0 | 0 |
22 | Locked | 40.946209 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
25 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 392 |
159 | Locked | 42 | 9.1 | 17222460 | 0 |
on 27-10-2021 14:06
Here's the power logs
To me my power levels look a bit high:
19 | 283000000 | 10.4 | 40.4 | QAM256 | 19 |
1 | 139000000 | 12.2 | 40.4 | QAM256 | 1 |
2 | 147000000 | 11.8 | 39 | QAM256 | 2 |
3 | 155000000 | 11.4 | 40.4 | QAM256 | 3 |
4 | 163000000 | 10.9 | 40.4 | QAM256 | 4 |
5 | 171000000 | 10.9 | 40.4 | QAM256 | 5 |
6 | 179000000 | 10.6 | 40.4 | QAM256 | 6 |
7 | 187000000 | 10.6 | 40.4 | QAM256 | 7 |
8 | 195000000 | 10.5 | 40.4 | QAM256 | 8 |
9 | 203000000 | 10.3 | 40.4 | QAM256 | 9 |
10 | 211000000 | 10.3 | 39 | QAM256 | 10 |
11 | 219000000 | 10.6 | 40.4 | QAM256 | 11 |
12 | 227000000 | 10.4 | 40.4 | QAM256 | 12 |
13 | 235000000 | 10.4 | 40.4 | QAM256 | 13 |
14 | 243000000 | 10.3 | 40.4 | QAM256 | 14 |
15 | 251000000 | 10 | 40.9 | QAM256 | 15 |
16 | 259000000 | 10 | 40.4 | QAM256 | 16 |
17 | 267000000 | 10.4 | 40.4 | QAM256 | 17 |
18 | 275000000 | 10.3 | 40.4 | QAM256 | 18 |
20 | 291000000 | 10.1 | 40.9 | QAM256 | 20 |
21 | 299000000 | 9.1 | 40.9 | QAM256 | 21 |
22 | 307000000 | 9.1 | 40.9 | QAM256 | 22 |
23 | 315000000 | 9.3 | 40.4 | QAM256 | 23 |
24 | 323000000 | 8.9 | 39 | QAM256 | 24 |
25 | 331000000 | 9.2 | 39 | QAM256 | 25 |
26 | 339000000 | 9.3 | 40.4 | QAM256 | 26 |
27 | 347000000 | 8.6 | 39 | QAM256 | 27 |
28 | 355000000 | 8.5 | 40.4 | QAM256 | 28 |
29 | 363000000 | 8.9 | 40.4 | QAM256 | 29 |
30 | 371000000 | 8.5 | 39 | QAM256 | 30 |
31 | 379000000 | 8.4 | 39 | QAM256 | 31 |
on 27-10-2021 14:29
on 27-10-2021 15:07
Upstream logs as requested:
1 | 25800000 | 38.5 | 5120 KSym/sec | 64QAM | 4 |
2 | 32600000 | 39.3 | 5120 KSym/sec | 64QAM | 3 |
3 | 39400000 | 39.3 | 5120 KSym/sec | 64QAM | 2 |
4 | 46200000 | 39.3 | 5120 KSym/sec | 64QAM | 1 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
the last few days logs:
Sun 24/10/2021 10:41:41 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 25/10/2021 10:58:31 | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 25/10/2021 10:59:40 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 25/10/2021 10:59:43 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 27/10/2021 11:03:08 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MA |
on 27-10-2021 17:44
on 27-10-2021 20:02
well putting the hub into modem mode completely killed it. It won't reboot. It won't reset its just a coffee jar shaped brick with a solid white light on it. I've got an engineer booked but having to use my friends inet to post this. So much for the work I have to complete tomorrow. I should state that yes i pressed the reset button for 60sec.,
on 27-10-2021 20:57
on 27-10-2021 21:31
Tried both sugestions and no activity at all. As I said the hub light is constant from power on ie white ring. There's no activity on ethernet ports either. Plugged a laptop in and I get unconnected cable, which I admit may be a failure with laptop but until I can borrow another laptop tomorrow I can't do anything differnet.
on 29-10-2021 11:42
Update
Just had an engineer visit he swapped the hub confirmed the other one was bricked. But speed still only 550Mb asked if there's anything he can do as this was the speed I was getting on, cheaper, M500. He said NO.
Is this true that this is going to be my limit if so I demand to be put back to M500 for the price I was paying (£46/month) instead of paying £62/month for no gain.
Not an happy customer.
on 01-11-2021 16:15
Hi Eckethump63,
Sorry to hear you're still experiencing some slow speeds,
Can you confirm if this is over a wired or wireless connection?
Alex_Rm
