on 25-01-2022 20:25
Hi there,
I've upgraded to 1GB but my Max traffic Rate is locked at 690000278 thus the only speed im getting is around 650, here are my details and logs;
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | cmreg-vmdg640-bbt078+voc-b.cm |
SFID | 157860 |
Max Traffic Rate | 690000278 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 157859 |
Max Traffic Rate | 44000278 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
Thu 01/01/1970 00:01:19 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 22/01/2022 12:30:06 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 22/01/2022 12:33:01 | 6 | SW Download INIT - Via Config file cmreg-vmdg640-bbt078+voc-b.cm |
Sat 22/01/2022 12:34:19 | 6 | SW download Successful - Via Config file |
Sat 22/01/2022 12:36:52 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 22/01/2022 13:03:15 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:21 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 22/01/2022 13:33:30 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 22/01/2022 14:16:34 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 23/01/2022 05:58:03 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 25/01/2022 13:38:11 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thanks in advance if anyone can help, I have reset the router number of times with no prevail, my network is 10GB. Thank you
on 25-01-2022 20:26
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
on 26-01-2022 11:30
If you upgraded via VOLT it takes 14 days for VM to activate this.
Otherwise try a 60 second factory pinhole reset as below, to force an update;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Failing this phone in to get VM to send the correct config file, or wait here a day or two for a VM Mod to pick this up.
on 01-02-2022 11:51
Hello Matsmad
Sorry to hear of the broadbadn speed confusion following your recent change to Volt, we appreciate you taking the time to raise this via the forums and welcome to the community.
It's been a few days since your post, is this something you still require assistance with? We do have some support here and as Adduxi has advised it can take up to 14 days for the Volt benefits to be applied to a Virgin Media account.
Rob
