on 21-08-2022 13:19
I’ve just moved into this flat and had my wifi delivered but I have no clue where I’m meant to plug it in! Here are all my options:
Any help would be much appreciated thankyou!
on 21-08-2022 14:26
on 21-08-2022 14:52
Hopefully this is clearer, thanks
on 21-08-2022 15:38
Top middle is possibly an F socket, but as picture is ‘straight on’ cannot say. Bottom middle looks like a TV socket. Top left is an NTL phone socket, bottom left is a BT phone socket. The two right hand sockets look like Ethernet. Have you looked elsewhere, perhaps at the other end of the Ethernet cables from those right hand sockets?
on 21-08-2022 15:54
@jessb12873 wrote:Hopefully this is clearer, thanks
Bottom middle looks like it could be a F-connector plug pushed inside the back box and hiding behind the faceplate and just visible through the hole. Can you actually access this plug/socket (bottom/middle faceplate in the 2nd pic) or is it pushed back inside the box and loose?
Also post up a decent pic of the final bottom RHS box (included on the first photo, bottom RHS but missing on the second).
on 21-08-2022 16:08
here is a photo of the bottom right one:
It won’t let me upload these pictures to actual quality because the picture is too big which is why I’m struggling to show these properly. However, this is the bottom middle socket again:
It has a spike similar to that of the isolator cable so i’m guessing it’s not that socket. It looks to be pushed inside the plate.
I also can’t see anything attached to the right hand side sockets like no wires or anything that I can follow.
on 21-08-2022 16:18
@jessb12873 wrote:here is a photo of the bottom right one:
Will need to wait for your pic's to be approved but I will make a guess that your VM cable could possibly be the middle/bottom cable and pushed inside the back box behind the faceplate.
Installers often seek to avoid drilling new holes for cables so they sometimes rip out an existing connection and take it over to for their own cable. It might be there was a TV aerial in that bottom/middle faceplate at one time before it was removed (or it could just be a broken TV aerial connection!).
Should be able to confirm/reject that idea with the next pic's when approved. Forum VIPs get to see the pic's early and may comment beforehand.
21-08-2022 16:48 - edited 21-08-2022 17:09
Behind the cracked faceplate (second pic in message #6, the very last photo posted) looks like you might find a connector that looks like the second photo here (just a short stub of cable with a plug on the end).
If so, that could possibly be the VM connection. Sometimes with earlier installations, or installations that have been messed with in the past, that's all that's left behind.
Is there a plastic VM wall box outside your home, usually grey or brown (where the cable from the street comes to your building)? It may have VM branding on it or branding from one of the past cable TV companies. If there is can you trace the cable from that outside wall box to your property? If it matches up with the suggestion above then that could well be it.
If your flat is in a purpose-built block of flats then the incoming cable may arrive in a central telecoms cupboard which you probably won't have access to.
on 21-08-2022 16:50
I think the next move is to take off some of the faceplates to see what is behind them.
on 23-08-2022 18:53
Hi jessb12873,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear that you're having some issues with completing the self installation. I think the best thing to do here would be to convert this visit to a manned installation. This will allow an engineer to come and get everything installed for you so they can ensure it's all plugged in to the correct boxes.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a private message regarding this. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
