manjusha
turn off wifi and work with LAN
HI,
I wish to choose only LAN connection and turn off wifi in home when my small child play around living room. When I was using EIR i could do it easily by pressing a button on the eir Hub instrument. Today we switched to virgin media. I can not switch off wifi  only and work LAN.
I truly don't want my son with brain inflammation exposed to 24-hour radiation. Could you help me to turn of wifi and use LAN, What is the procedure?
Dr. MANJUSHA
  • 15.66K
  • 1.63K
  • 3.52K
Re: turn off wifi and work with LAN
Unfortunately this is the forum for U.K. customers.
Support in Eire is here:
https://www.virginmedia.ie/contact/
  • 2.63K
  • 129
  • 368
jpeg1
Trouble shooter
But the answer is the same - if you log on to the Hub you will find a setting to turn off the WiFi.
If you really want to protect your family from electrical fields you will need to turn off the main electricity supply to your house, because the wiring surrounds them with a much more powerful field than the WiFi. And then of course the WiFi will definitely be off.
  • 7.97K
  • 823
  • 1.24K
Google is your friend (so they say)
https://www.virginmedia.com/help/virgin-media-hub-turn-off-wireless
