hi ..over the last 4 or 5 days my hub has decided it does not want to stay on white light and has changed to red. ive done the factory reset 3 times which when starts up it goes white then after 10 mins or so it flicks to red . everything seems to still work fine but unsure to why this has all of a sudden decided to go red. is there a fault with the hub or is it something has happened at your end.
many thanks
mat
