  • 12
Jonjon1239
Message 1 of 5
Weak WiFi Signal and Dropout
I've had multiple engineer visits this year and I've had to buy two range extenders for 2.4ghz and 5ghz however I keep getting weak signal in my house which was never a problem for 4 years. My log is below, can someone help or advise?
31/07/2019 19:34:19ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2019 12:50:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2019 04:42:37ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2019 09:12:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2019 15:46:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2019 02:32:58noticeSW Download INIT - Via NMS
05/08/2019 02:34:34noticeSW download Successful - Via NMS
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2019 09:01:27ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2019 16:51:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/08/2019 11:37:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/08/2019 11:19:25ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/08/2019 18:49:28ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2019 05:39:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2019 19:00:40ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2019 22:30:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/08/2019 04:51:17ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/08/2019 14:42:0ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2019 10:31:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 2.79K
  • 140
  • 407
jpeg1
Trouble shooter
Message 2 of 5
Re: Weak WiFi Signal and Dropout
We need to establish whether this is a WiFi problem or the incoming signal at fault.
What speeds do you get with a device connected to the Hub by ethernet cable?
Can you copy and paste the downstream and upstream data please.
  • 12
Jonjon1239
Message 3 of 5
Hi There
The speeds that I am getting are fine it's more of there being a lot of drop out and weak signal.
12990000002.233256 qam21
21870000007.534256 qam7
3195000000734256 qam8
42030000006.334256 qam9
52110000006.334256 qam10
62190000005.634256 qam11
72270000005.534256 qam12
82350000004.934256 qam13
92430000004.834256 qam14
10251000000434256 qam15
11259000000433256 qam16
122670000003.233256 qam17
132750000003.233256 qam18
142830000002.933256 qam19
152910000002.733256 qam20
163070000001.933256 qam22
173150000001.233256 qam23
18323000000133256 qam24
19379000000-0.932256 qam25
20387000000-1.732256 qam26
21395000000-232256 qam27
22403000000-2.732256 qam28
23411000000-2.931256 qam29
24419000000-3.531256 qam30
1Locked3370707050
2Locked34.41411430
3Locked34.9328150
4Locked34.9434890
5Locked34.9522750
6Locked34.4709370
7Locked34.32717890
8Locked34.42204070
9Locked34.31770250
10Locked34.34162710
11Locked33.97562060
12Locked33.816026770
13Locked33.814924530
14Locked33.810132830
15Locked33.815555450
16Locked33.3332689925
17Locked33.349739160
18Locked33.330301890
19Locked32.6203688968
20Locked32.61919805714
21Locked32.53583010152
22Locked32.2727393530
23Locked31.62321388220
24Locked31.9140423791
6
  • 12
Jonjon1239
Message 4 of 5
Upstream bonded channels Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1536999664.275512064 qam2
2394000254.15512064 qam4
3602999474.3512064 qam1
4461999964.2512064 qam3
Upstream bonded channels Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
  • 2.79K
  • 140
  • 407
jpeg1
Trouble shooter
Message 5 of 5
Your connection is in a very poor state. The downstream levels are unbalanced and the SNR is too low.
Check that the coax connections to the Hub are tight. If that doesn't help then you will have to call 150 and report the fault. It's going to need an engineer visit.
