PPinner70
Vivid 350 Optical Fibre Speed
We don't seem to be getting the speed we expected from this package - is this usual?
PING ms
19
 DOWNLOAD Mbps
32.14
 UPLOAD Mbps
19.04
  • 8.57K
  • 877
  • 1.33K
Re: Vivid 350 Optical Fibre Speed
Depends on how you are doing the test.  Are you testing on a gigabit enabled computer/laptop booted up into safe+networking mode, connected to the Hub put into modem mode with a new Cat5e/6a cable?  If not, try that and report back on speeds you get from  speedtest.net.
  • 19.22K
  • 1.68K
  • 4.22K
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, and operational config don't worry about the formatting we can easily read it.. try and avoid using screen shots..
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
