on 23-03-2023 11:23
I have been having intermittent connection issues for a couple of months now and have had 1 engineer visit during this time.
My current configuration is VM Hub 3.0 (in modem mode) connected to a 3rd party router.
I will post logs in a post below.
I hope someone can look over these and provide some help as VM tech support on the phone are no help at all.
on 23-03-2023 11:24
1 | 171000000 | 5 | 38 | 256 qam | 5 |
2 | 139000000 | 5.3 | 38 | 256 qam | 1 |
3 | 147000000 | 5 | 38 | 256 qam | 2 |
4 | 155000000 | 5 | 38 | 256 qam | 3 |
5 | 163000000 | 4.9 | 38 | 256 qam | 4 |
6 | 179000000 | 4.9 | 38 | 256 qam | 6 |
7 | 187000000 | 4.9 | 38 | 256 qam | 7 |
8 | 195000000 | 4.6 | 38 | 256 qam | 8 |
9 | 203000000 | 4.4 | 38 | 256 qam | 9 |
10 | 211000000 | 4.3 | 38 | 256 qam | 10 |
11 | 219000000 | 3.7 | 38 | 256 qam | 11 |
12 | 227000000 | 3.4 | 38 | 256 qam | 12 |
13 | 235000000 | 3 | 38 | 256 qam | 13 |
14 | 243000000 | 2.7 | 38 | 256 qam | 14 |
15 | 251000000 | 3 | 38 | 256 qam | 15 |
16 | 259000000 | 3 | 38 | 256 qam | 16 |
17 | 267000000 | 3.2 | 38 | 256 qam | 17 |
18 | 275000000 | 3 | 38 | 256 qam | 18 |
19 | 283000000 | 3.2 | 38 | 256 qam | 19 |
20 | 291000000 | 3.4 | 38 | 256 qam | 20 |
21 | 299000000 | 3.7 | 38 | 256 qam | 21 |
22 | 307000000 | 3.9 | 38 | 256 qam | 22 |
23 | 315000000 | 3.7 | 38 | 256 qam | 23 |
24 | 323000000 | 3.9 | 40 | 256 qam | 24 |
1 | Locked | 38.6 | 79268 | 9905 |
2 | Locked | 38.6 | 71841 | 10742 |
3 | Locked | 38.6 | 75240 | 10787 |
4 | Locked | 38.9 | 70374 | 9516 |
5 | Locked | 38.9 | 73815 | 9358 |
6 | Locked | 38.9 | 73550 | 9100 |
7 | Locked | 38.6 | 67332 | 9711 |
8 | Locked | 38.6 | 69306 | 9241 |
9 | Locked | 38.9 | 121586 | 9133 |
10 | Locked | 38.9 | 114703 | 8230 |
11 | Locked | 38.9 | 82876 | 15478 |
12 | Locked | 38.6 | 156244 | 62997 |
13 | Locked | 38.6 | 71508 | 8946 |
14 | Locked | 38.9 | 60498 | 8113 |
15 | Locked | 38.6 | 56803 | 7886 |
16 | Locked | 38.6 | 61133 | 8524 |
17 | Locked | 38.6 | 61788 | 8341 |
18 | Locked | 38.6 | 64888 | 9264 |
19 | Locked | 38.9 | 60150 | 7888 |
20 | Locked | 38.6 | 58473 | 7615 |
21 | Locked | 38.9 | 59198 | 7652 |
22 | Locked | 38.9 | 62035 | 8599 |
23 | Locked | 38.9 | 64496 | 9587 |
24 | Locked | 40.3 | 60237 | 8281 |
on 23-03-2023 11:25
1 | 36600000 | 45.8 | 5120 | 64 qam | 3 |
2 | 23600000 | 45.3 | 5120 | 64 qam | 5 |
3 | 30100000 | 45.8 | 5120 | 64 qam | 4 |
4 | 43100000 | 45.8 | 5120 | 64 qam | 2 |
5 | 49600000 | 45.8 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 12 | 0 |
2 | ATDMA | 0 | 0 | 9 | 0 |
3 | ATDMA | 0 | 0 | 13 | 0 |
4 | ATDMA | 0 | 0 | 8 | 0 |
5 | ATDMA | 0 | 0 | 4 | 0 |
on 23-03-2023 11:25
23/03/2023 11:12:15 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/03/2023 04:49:31 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/03/2023 18:58:46 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/03/2023 08:05:11 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/03/2023 08:05:11 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/03/2023 13:54:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/03/2023 20:05:11 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/03/2023 20:05:11 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/03/2023 00:25:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/03/2023 08:05:10 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/03/2023 08:05:10 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/03/2023 17:00:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/03/2023 13:24:30 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/03/2023 13:24:30 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/03/2023 13:24:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/03/2023 13:24:23 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
11/03/2023 13:24:20 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 23-03-2023 11:38
Downstream Power and SNR look OK, Upstream Power and Modulation mode look OK.
What sticks out are the Post RS ( not corrected ) errors across all Downstream channels.
These accumulate from the last Hub reboot - it would be worth restarting the Hub to see if they are still being recorded.
Check the coax cable is secure at the back of the Hub and at the wall.
Call the automated local faults line 0800 561 0061 to see if there are any known issues.
on 23-03-2023 12:23
The Post RS errors do come back pretty quickly after a restart. I will restart now and post a output after 1 hour.
On the last engineer visit he put a new splitter on the wall outside and new housing (old one was hanging off) and put a new attenuator connecting into the back of the router so I believe these are all tight but I will double check.
on 24-03-2023 08:56
I restarted @ 12:30 yesterday and this is the error's this morning:
1 | Locked | 38.6 | 411 | 31 |
2 | Locked | 38.9 | 412 | 34 |
3 | Locked | 38.6 | 454 | 76 |
4 | Locked | 38.9 | 405 | 45 |
5 | Locked | 38.9 | 412 | 38 |
6 | Locked | 38.9 | 389 | 52 |
7 | Locked | 38.6 | 473 | 49 |
8 | Locked | 38.9 | 409 | 34 |
9 | Locked | 38.9 | 397 | 33 |
10 | Locked | 38.6 | 389 | 29 |
11 | Locked | 38.9 | 437 | 44 |
12 | Locked | 38.9 | 435 | 55 |
13 | Locked | 38.9 | 426 | 46 |
14 | Locked | 38.9 | 383 | 46 |
15 | Locked | 38.9 | 358 | 24 |
16 | Locked | 38.6 | 419 | 33 |
17 | Locked | 38.9 | 391 | 60 |
18 | Locked | 38.9 | 438 | 79 |
19 | Locked | 38.9 | 388 | 31 |
20 | Locked | 38.6 | 363 | 44 |
21 | Locked | 38.9 | 391 | 30 |
22 | Locked | 38.9 | 398 | 53 |
23 | Locked | 38.6 | 441 | 64 |
24 | Locked | 38.9 | 421 | 40 |
on 24-03-2023 10:48
Unless there is an area fault you will need a technician’s visit to rectify.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
