Googers
Message 1 of 7
Urgent: Solid green base and wifi lights, flashing internet light
Hi folks,
I need an urgent fix as Virgin can't get a technician out til Saturday and I'm working from home this week - internet is an absolute necessity.
I was having connectivity problems so power cycled the Hub 3.0. Upon rebooting it now has a solid green work light, flashing internet arrows, and a solid base light.
I have power cycled again and unplugged everything numerous times to no avail. I cannot wait until Saturday for a tech.
Please help!
  • 7.9K
  • 816
  • 1.23K
Message 2 of 7
Re: Urgent: Solid green base and wifi lights, flashing internet light
Is the internet actually working though ?  Is it doing a firmware update (these can take some time)?
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
Googers
Message 3 of 7
Thanks for the response jbrennand.
I do not have any internet access but am able to access the router's UI via Ethernet connection only. My mobile cannot access the router despite the WiFi showing as operational.
Nothing on the Hub UI is showing that an update is going on.
May pop out for an hour and see if it resolves itself if left to its own devices.
Brief update - just received this text:
Hi, it's Virgin Media. We've put your service visit on hold while we investigate a network problem affecting your services. We'll update you when this is fixed.
  • 12.79K
  • 974
  • 2.91K
Message 4 of 7
message says it all - they cancel tech visits if its an area fault - you are in their hands - hopefully they will get it sorted quickly and the hub will connect
____________________
Tony
  • 3.12K
  • 116
  • 156
Forum Team (Retired) Louise_F
Message 5 of 7
Hi Googers,
There was a fault we became aware of that has since been resolved.
How have things been since you last posted? I'm hoping all is working as it should be now but if not, and you're still having an issue, come back and let me know.
Louise
Forum Support Team
New around here? Find out more about the Community by checking our "Getting started guide"
Googers
Message 6 of 7
Hi Louise,
Yep all resolved now! Relieved it was only down for the day and managed to get back up and running the morning after.
Cheers.
  • 3.12K
  • 116
  • 156
Message 7 of 7
Hi Googers,
Thanks for coming back and letting us know things are resolved now.
If you have any further issues you know where to find me.
In the meantime, don't be a stranger around the Community! Feel free to browse through the Boards and jump into a thread if you have any advice or tips that may be of use to others.
Take care,
Louise
