Kc24681
  • 6
Message 1 of 15
Telewest cable doesn’t fit
I have bought a virgin media package but cannot get the internet cable to fit to the old telewest box. Any suggestions ?
JOE-C
  • 106
  • 18
  • 21
Message 2 of 15
Re: Telewest cable doesn’t fit
Good morning,
So we can assist you with this are you able to provide photos of the cable and telewest point that you have?
Thank You
Joe
  • 5.86K
  • 485
  • 1.49K
Message 3 of 15
You may need one of these  Tristar Data cable coupler | DIY at B&Q  to join the two cables.
-tony-
  • 18.97K
  • 1.44K
  • 3.64K
Message 4 of 15
the old telewest box should have a screw connector the new cables from VM are push fit - they should connect but they can need some force to get then to fit
____________________
Tony.
Kc24681
  • 6
Message 5 of 15
Hello yes here are the two wires
Kc24681
  • 6
Message 6 of 15
Kc24681
  • 6
Message 7 of 15
Brava210
  • 298
  • 8
  • 51
Fibre optic
Message 8 of 15
Unscrew that cable from the bottom of the wall box, and push the new cable into that socket
Virgin BB 200, Hub 3, 3 x V6, TP-Link Deco AX20 x1, M5 x2 - United Artists/Telewest/VM Since 1990
Kc24681
  • 6
Message 9 of 15
The cable won’t unscrew from wall socket?
Brava210
  • 298
  • 8
  • 51
Fibre optic
Message 10 of 15
It will, you may need pliers or such like
It should be nut shaped, so even an adjustable spanner.
