Paul_2020
  • 15
Superhub and TV same room help
Been having issues with internet slow speeds, been waiting forever for a response. so today i tried fixing myself.
removed the splitter and connected superhub straight to single cable running through wall.. that fixed my consistently poor download speeds
now the problem is i dont have anywhere to plug the tv connection to as ive removed the splitter.. any suggestions on whats best to do? thanks
Ernie_C
  • 18.9K
  • 2.07K
  • 4.74K
Re: Superhub and TV same room help
Removing the splitter has altered the signal levels so that they fix your internet issue.
To get your TV, you need to put the splitter back in.
You need to get an engineer out to fix the signal levels with the splitter in place.
