  • 6
Siuko
Message 1 of 11
Super Hub 3 - unstable connection for first 10 minutes
I have a super hub 3 which has an intermittent and slow connection for the first 10-15 minutes of using it. For example after not using the internet over night or when I'm at work. When I then try using it on my computer it works very slowly.
When pinging google the connection responses will be as below
After about 15 minutes it will then start responding constantly with a time of around 14-19ms and for the rest of the time using the internet it will be fast loading websites and playing games
Time	Priority	Description
2019-02-01 09:56:55.00	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-01 15:09:08.00	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-01 23:01:25.00	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-01 23:45:56.00	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-02 00:59:49.00	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-02 01:54:34.00	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-06 15:04:56.00	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-07 21:06:24.00	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-07 22:04:35.00	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-11 02:01:51.00	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-11 15:28:01.00	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-11 17:45:56.00	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-11 23:00:41.00	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-14 07:57:10.00	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-16 08:57:04.00	Error	DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-17 13:50:43.00	Error	DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:29.00	Warning!	Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:29.00	Warning!	MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-17 21:10:49.00	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-02-17 21:26:52.00	Warning!	RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
1	299000000	2.5	38	256 qam	21
2	323000000	2.9	38	256 qam	24
3	315000000	2.9	40	256 qam	23
4	307000000	2.7	38	256 qam	22
5	291000000	2.4	38	256 qam	20
6	283000000	2.7	40	256 qam	19
7	275000000	2.7	40	256 qam	18
8	267000000	2.7	38	256 qam	17
9	259000000	2.9	38	256 qam	16
10	251000000	2.9	38	256 qam	15
11	243000000	2.7	38	256 qam	14
12	235000000	3.2	38	256 qam	13
13	227000000	3.7	38	256 qam	12
14	219000000	3.7	38	256 qam	11
15	211000000	3.9	38	256 qam	10
16	203000000	3.9	36	256 qam	9
17	195000000	4	40	256 qam	8
18	187000000	4.5	38	256 qam	7
19	179000000	4.6	38	256 qam	6
20	171000000	4.6	37	256 qam	5
21	163000000	4.5	37	256 qam	4
22	155000000	4.5	36	256 qam	3
23	147000000	4.5	38	256 qam	2
24	139000000	4.5	38	256 qam	1
Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
1	Locked	38.9	30	0
2	Locked	38.9	14	0
3	Locked	40.3	11	0
4	Locked	38.9	17	0
5	Locked	38.9	7	0
6	Locked	40.3	11	0
7	Locked	40.3	5	0
8	Locked	38.9	9	0
9	Locked	38.9	7	0
10	Locked	38.9	8	0
11	Locked	38.9	7	0
12	Locked	38.6	13	0
13	Locked	38.6	22	0
14	Locked	38.9	9	0
15	Locked	38.9	7	0
16	Locked	36.3	9	0
17	Locked	40.3	14	0
18	Locked	38.9	26	0
19	Locked	38.9	22	0
20	Locked	37.3	21	0
21	Locked	37.3	26	0
22	Locked	36.3	22	0
23	Locked	38.9	10	0
24	Locked	38.9	10	0
Channel	Frequency (Hz)	Power (dBmV)	Symbol Rate (ksps)	Modulation	Channel ID
1	39400000	40.3	5120	16 qam	92
2	25800000	38.8	5120	16 qam	94
3	32600000	39.3	5120	16 qam	93
4	46200000	40.3	5120	16 qam	91
Channel	Channel Type	T1 Timeouts	T2 Timeouts	T3 Timeouts	T4 Timeouts
1	ATDMA	0	0	0	0
2	ATDMA	0	0	0	0
3	ATDMA	0	0	0	0
4	ATDMA	0	0	0	0
Any help you can provide will be appreciated.
I have reset the super hub to default and then put in modem mode - this made no difference
Thanks 😄
  • 12.45K
  • 471
  • 1.11K
Message 2 of 11
Re: Super Hub 3 - unstable connection for first 10 minutes
Can't see pings to google yet but I'm guessing it show high pings?
From what your say is that you need to warm up the connection when its not in use. Do you leave the hub on all the time? If you leave a PC on and do ping -t 194.168.4.100 does that stop the slow connection?
  • 6
Siuko
Message 3 of 11
Thanks for the reply
Yeah the google ping shows high pings and intermittently there is no reply
'Warming up the connection' would be a good term for it - once the ping stabilises after its been going for about 15 minutes the connection stays fine for as long as I use it
It is only when it is left with nothing trying to use it (all computers off etc) when it then needs to be warmed up again
The hub is left on all the time
I didn't really want to have to leave my pc on over night or when I'm at work - is there any way to setup a ping to run from the hub itself?
  • 12.45K
  • 471
  • 1.11K
Message 4 of 11
Someone else had a issue like this but they turned the hub off at night and no in the morning.
You could use BQM to ping your hub if you set it up to 'Respond to ICMP echo requests sent to WAN IP'
  • 6
Siuko
Message 5 of 11
Tried BQM as you mentioned
Initially it doesn't seem to be helping > https://www.thinkbroadband.com/broadband/monitoring/quality/share/e5c5d53e1b9fb2195758659a8e62c2c8ac...
Turned off the PC and went out for a bit and connection has same issue for first 10-15 minutes
BQM also shows the issue on the graph
  • 12.45K
  • 471
  • 1.11K
Message 6 of 11
It could be a fault with your hub do you get any t# timeouts in the hub?
  • 6
Siuko
Message 7 of 11
Do you mean lines like -
  • 6
Siuko
Message 8 of 11
You mentioned it possibly being an issue with my Hub
How do I go about getting a new one? 😄
  • 4.39K
  • 302
  • 261
Message 9 of 11
Hi Siuko,
We can have a look at your hub from here so we'll pop you a personal message and take it from there.
Thanks.
Emma_C - Forum Team
  • 6
Siuko
Message 10 of 11
Hi Emma
I've now cancelled the engineer appointment as I worked out what was causing it
It was the oculus rift update service that was using that much bandwidth it was affecting all machines on my network until it had finished updating!! (it affecting all computers on my network made me think it wasn't something on my pc that could cause it! I've never seen anything like it - but when googling it - it is a known issue)
Now I've disabled the service I don't get the initial slowness
Sorry for wasting your time and thank you so much for the help you provided
David
