I can already see from the Downstream data that there is a problem. The recommended power range is from -6 dBmV to +10 dBmV and several of your channels are well below this range. Probably as a result of this you are getting an awful lot of post-RS errors when there should be none. The signal to noise ratio should be at least 34.5db, the higher the better, but many of your channels are way below this indicating a noisy connection. It also looks like only two of the four Upstream channels are active.
In short, this is not a good connection and will require an engineer's visit to sort it out. Possibly something as simple as putting you on a higher power tapping point in the street cabinet will resolve the problem.
In the meantime, just check that your cable connections are secure in the back of the hub and at the wall socket.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
