08-10-2021 07:37 - edited 08-10-2021 07:49
Hi all,
Upgraded to Gigabit yesterday. Barely getting 500 MBits/sec. Also, overnight our internet connection went down. It appeared that everything was connected (pfSense router reported it had an IP address, but no traffic being routed). Repowered the SuperHub, and it's back for now.
Superhub is in modem mode, with a pfsense router connected. All was previously fine when on 350M package, giving expected speeds up and down. Will post hub status in following messages.
on 08-10-2021 07:38
3.0 Downstream channels
12 | 499000000 | 6.500000 | 40.366287 | QAM256 | 12 |
1 | 411000000 | 5.400002 | 40.366287 | QAM256 | 1 |
2 | 419000000 | 5.599998 | 38.605377 | QAM256 | 2 |
3 | 427000000 | 5.699997 | 38.983261 | QAM256 | 3 |
4 | 435000000 | 6.000000 | 38.605377 | QAM256 | 4 |
5 | 443000000 | 6.199997 | 40.366287 | QAM256 | 5 |
6 | 451000000 | 6.599998 | 40.366287 | QAM256 | 6 |
7 | 459000000 | 6.199997 | 40.366287 | QAM256 | 7 |
8 | 467000000 | 6.199997 | 40.366287 | QAM256 | 8 |
9 | 475000000 | 6.000000 | 40.366287 | QAM256 | 9 |
10 | 483000000 | 6.199997 | 40.366287 | QAM256 | 10 |
11 | 491000000 | 6.300003 | 40.366287 | QAM256 | 11 |
13 | 507000000 | 6.400002 | 40.366287 | QAM256 | 13 |
14 | 515000000 | 6.500000 | 40.366287 | QAM256 | 14 |
15 | 523000000 | 6.599998 | 40.366287 | QAM256 | 15 |
16 | 531000000 | 6.800003 | 40.366287 | QAM256 | 16 |
17 | 539000000 | 7.000000 | 40.366287 | QAM256 | 17 |
18 | 547000000 | 7.099998 | 40.946209 | QAM256 | 18 |
19 | 555000000 | 7.099998 | 40.366287 | QAM256 | 19 |
20 | 563000000 | 7.300003 | 40.366287 | QAM256 | 20 |
21 | 571000000 | 7.400002 | 40.366287 | QAM256 | 21 |
22 | 579000000 | 7.400002 | 40.366287 | QAM256 | 22 |
23 | 587000000 | 7.400002 | 40.946209 | QAM256 | 23 |
24 | 595000000 | 7.699997 | 40.366287 | QAM256 | 24 |
25 | 603000000 | 7.900002 | 40.366287 | QAM256 | 25 |
26 | 611000000 | 7.800003 | 40.366287 | QAM256 | 26 |
27 | 619000000 | 7.800003 | 40.366287 | QAM256 | 27 |
28 | 627000000 | 7.400002 | 40.366287 | QAM256 | 28 |
29 | 635000000 | 7.300003 | 40.366287 | QAM256 | 29 |
30 | 643000000 | 6.900002 | 40.366287 | QAM256 | 30 |
31 | 651000000 | 7.000000 | 40.946209 | QAM256 | 31 |
12 | Locked | 40.366287 | 7 | 0 |
1 | Locked | 40.366287 | 6 | 0 |
2 | Locked | 38.605377 | 0 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
4 | Locked | 38.605377 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 1 | 0 |
13 | Locked | 40.366287 | 7 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.366287 | 7 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.946209 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.946209 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.366287 | 6 | 0 |
26 | Locked | 40.366287 | 7 | 0 |
27 | Locked | 40.366287 | 6 | 0 |
28 | Locked | 40.366287 | 1 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 1 | 0 |
31 | Locked | 40.946209 | 0 | 0 |
41 | 96 | 4K | 1880 | QAM4096 | 728 |
41 | Locked | 42 | 5.1 | 71272 | 0 |
on 08-10-2021 07:38
3.0 Upstream channels
1 | 32600000 | 42.520599 | 5120 KSym/sec | 64QAM | 9 |
2 | 53700000 | 42.770599 | 5120 KSym/sec | 64QAM | 6 |
3 | 46200000 | 42.520599 | 5120 KSym/sec | 64QAM | 7 |
4 | 39400000 | 42.520599 | 5120 KSym/sec | 64QAM | 8 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 08-10-2021 07:39
General Configuration
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | cmreg-vmdg640-bbt076-b.cm |
SFID | 61558 |
Max Traffic Rate | 1230000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 61557 |
Max Traffic Rate | 55000270 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 08-10-2021 07:39
Thu Jan 1 00:01:19 1970 | 4 | Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:52 1970 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 7 14:41:21 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 7 14:44:27 2021 | 6 | SW Download INIT - Via Config file cmreg-vmdg640-bbt076-b.cm |
Thu Oct 7 14:45:41 2021 | 6 | SW download Successful - Via Config file |
Thu Oct 7 14:48:12 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 7 14:56:19 2021 | 5 | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 7 14:56:25 2021 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 7 15:02:44 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 7 15:21:50 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:21 1970 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Oct 8 06:27:38 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Oct 8 06:27:48 2021 | 5 | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Oct 8 06:28:03 2021 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 08-10-2021 07:42
on 08-10-2021 07:55
Very low error counts suggest the hub had been restarted shortly before the status data was taken. It's usually best to post status data after a good few hours of run time (somewhere in the 12-48 hour range), because after a restart the hub erases all error counters, and the channels are freshly negotiated and may not be representative of the state they drift into if there's noise or power issues. Having 1 Gbps is much more demanding of line quality than slower speeds, it's quite possible that any underlying issue existed before, but are only apparent now.
I do observe that the power levels slope the wrong way (potentially an incorrectly setup amplifier in a street cabinet), but can't say whether the extent of that slope issue is great enough to cause speed problems. DOCSIS is like most analogue technologies (for the most part) a pretty fault tolerant system, but at 1 Gbps any minor issues that don't affect lower speeds can crawl out of the woodwork.
If you haven't already, could be worth undoing, wiping and remaking all coax joints with any nuts secured finger tight, checking cables for pinch or crush damage, and that all coax is VM supplied, and if there's a brown omnibox on the outside property wall, opening that and doing the same with the coax joints in that.
on 08-10-2021 08:46
Yes, that data was posted about an hour after the hub was restarted to fix the problem that occurred overnight. I'll monitor the error counts, and post again later today.
Thanks for the advice regarding checking connections etc., will do that.
Andy
on 10-10-2021 00:26
Ok, it's been running about 36 hours or so now. New results:
12 | 499000000 | 6.599998 | 40.366287 | QAM256 | 12 |
2 | 419000000 | 5.599998 | 38.983261 | QAM256 | 2 |
3 | 427000000 | 5.800003 | 38.983261 | QAM256 | 3 |
4 | 435000000 | 6.000000 | 38.983261 | QAM256 | 4 |
6 | 451000000 | 6.699997 | 40.366287 | QAM256 | 6 |
7 | 459000000 | 6.300003 | 40.366287 | QAM256 | 7 |
8 | 467000000 | 6.300003 | 40.946209 | QAM256 | 8 |
9 | 475000000 | 6.099998 | 40.366287 | QAM256 | 9 |
10 | 483000000 | 6.400002 | 40.366287 | QAM256 | 10 |
11 | 491000000 | 6.400002 | 40.366287 | QAM256 | 11 |
13 | 507000000 | 6.500000 | 40.366287 | QAM256 | 13 |
14 | 515000000 | 6.599998 | 40.366287 | QAM256 | 14 |
15 | 523000000 | 6.800003 | 40.366287 | QAM256 | 15 |
16 | 531000000 | 6.900002 | 40.366287 | QAM256 | 16 |
17 | 539000000 | 7.099998 | 40.366287 | QAM256 | 17 |
18 | 547000000 | 7.099998 | 40.366287 | QAM256 | 18 |
19 | 555000000 | 7.300003 | 40.366287 | QAM256 | 19 |
20 | 563000000 | 7.500000 | 40.946209 | QAM256 | 20 |
21 | 571000000 | 7.599998 | 40.366287 | QAM256 | 21 |
22 | 579000000 | 7.800003 | 40.366287 | QAM256 | 22 |
23 | 587000000 | 7.599998 | 40.366287 | QAM256 | 23 |
24 | 595000000 | 7.800003 | 40.366287 | QAM256 | 24 |
25 | 603000000 | 8.000000 | 40.946209 | QAM256 | 25 |
26 | 611000000 | 7.800003 | 40.946209 | QAM256 | 26 |
30 | 643000000 | 7.000000 | 40.366287 | QAM256 | 30 |
31 | 651000000 | 7.099998 | 40.366287 | QAM256 | 31 |
12 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
4 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 40.366287 | 1 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 2 | 0 |
15 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.366287 | 1 | 0 |
20 | Locked | 40.946209 | 0 | 0 |
22 | Locked | 40.366287 | 1 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 1 | 0 |
25 | Locked | 40.946209 | 2 | 0 |
26 | Locked | 40.946209 | 1 | 0 |
27 | Locked | 40.366287 | 2 | 0 |
28 | Locked | 40.366287 | 2 | 0 |
29 | Locked | 40.366287 | 1 | 0 |
30 | Locked | 40.366287 | 2 | 0 |
31 | Locked | 40.366287 | 1 | 0 |
41 | Locked | 42 | 5.3 | 328924711 | 0 |
on 10-10-2021 00:27
1 | 32600000 | 42.770599 | 5120 KSym/sec | 64QAM | 9 |
2 | 53700000 | 43.270599 | 5120 KSym/sec | 64QAM | 6 |
3 | 46200000 | 42.770599 | 5120 KSym/sec | 64QAM | 7 |
4 | 39400000 | 42.770599 | 5120 KSym/sec | 64QAM | 8 |
